Asus A8N-SLI Deluxe
  • badguyswant
    • Mar 2011
    • 12
    Asus A8N-SLI Deluxe
    Hello to everybody on this forum. i received this board from a buddy who said he couldn't get it to post. Iv got it to post but when i load all 4 ram slots up with ram it does not post. but a single stick it will post just fine. also when trying to install windows it is extremely slow and it will eventually just freeze up. These are the caps on the board. None appear to be bulging though.
    5 1500uf 6.3v KZG
    6 1000uf 16v Rubycon MBZ
    22 820uf 6.3v OST RLX(not sure what series this is)
    2 470uf 16v KZG
    Will replacing these caps mabye make the board stable? Thanks for any help. If you need a picture i will try to post one.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Asus A8N-SLI Deluxe
    KZG capacitors are known to failwithout bloating.
    The OST are crap too. (RLX is the series, OST is the manufacturer).
    The Rubycon caps are high quality; do not bother replacing them.
    Keep in mind this motherboard has a "faulty" nVidia chipset... that may or may not be causing any of your issues.
    • badguyswant
      • Mar 2011
      • 12
      Thanks for you reply shovenose. i really appreciate it. i have found some replacements for the KZG and OST. for the 1500uf 6.3v can i use 1500uf 6.3 caps they say 105C FJ on the side. same as for the 820 6.3v they same FJ on the side. Thanks!
      • c_hegge
        • Sep 2009
        • 5219
        No it doesn't. The nForce 4 was the last good chipset. Remember, this board is a s939. It's only sAM2, 775 and possibly some AM3 chipstes that were affected. What usually goes wrong with these boards is that the chipset fan quits which cooks the chipset (or they just get the ASDS/ Asus Sudden Death Syndrome).
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          How much Ram? 4 sticks of what? matched pairs?
          What Bios is it running?
          • mockingbird
            • Dec 2008
            • 5484
            5 1500uf 6.3v KZG
            2 470uf 16v KZG
            Leave the 16V 1000uF Rubycon MBZ. Replace everything else.
            The 6.3V 1500 KZG, 6.3V 820uF RLX and 16V 470 KZG are all 8mm and should be replaced with equivalents. Rubycon MBZ/MCZ, Sanyo WG, Nichicon HM/HN and Samxon GD/GC are all good replacements and these boards work great once they're re-capped. Again, make sure to get 8mm caps.
            You better be proficient at soldering. The lead holes are very small so there's always a risk of ripping off the pads if you don't have the proper technique/equipment (It can be done with cheap equipment if you have good technique).
            • badguyswant
              • Mar 2011
              • 12
              Replaced All KZG and OSt with Panasonic FJ. board works fine now went under prime 95 blend for a full 24 hours without error. All ram slots are working properly now. Thanks For the help shovenose, C_hegge and mockingbird. now to find out what i should do with this board. Might build a server out of it or something. Thanks again!
              • badguyswant
                • Mar 2011
                • 12
                Also having trouble updating bios
                • mockingbird
                  • Dec 2008
                  • 5484
                  What's the problem? You do so from DOS. I beieve asus uses aflash or something like that. Hook up an old floppy drive and make a boot disk from Windows. Get rid of some of the unecessary stuff on the boot disk so that you'll have rom for aflash and the bios file. Flash away.
                  IF you want, I can look up an SLIC 2.0 Bios for you. I'm almost certain there's one floating around.
                  • mariushm
                    • May 2011
                    • 3799
                    If you don't have a floppy, get the ISO image of FreeDOS from here: http://www.freedos.org/freedos/files/
                    Add the bios image plus the dos aplication to the ISO image using PowerISO or any other freeware/shareware.
                    Then, burn a CD/DVD image, boot from computer from CD/DVD and flash the bios.
                      ASUS ZenBook UX490UA-77DHDAB1 Notebook 3 Deluxe Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX490UA-77DHDAB1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-77DHDAB1 boardview and UX490UA-77DHDAB1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 09:37 AM
                      ASUS ZenBook UX490UA Notebook 3 Deluxe Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX490UA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA boardview and UX490UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ZenBook...
                      09-06-2024, 08:29 AM
                      ASUS ZenBook UX490UA-IH74-BL Notebook 3 Deluxe Specification for Upgrade or Repair
                      This specification for the ASUS ZenBook UX490UA-IH74-BL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-IH74-BL boardview and UX490UA-IH74-BL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-06-2024, 06:48 AM
                      09-06-2024, 06:30 AM
