MSI MS-6340 Rev 1 - epic capacitor failure
  • Lukeno94
    • Feb 2012
    • 6
    I recently picked up a bunch of computer parts, and computers (sadly I didn't have enough space and two of the machines there may well have since been scrapped... ) and in this motherboard, I found perhaps one of the worst sets of capacitors I've ever seen! I've stripped down the power supply and could see no obvious issues inside it, and it definitely powered on the machine, but having no other methods of testing it, I cannot determine if it is truly good or not.
    Unfortunately I can neither justify the expense of recapping the board, nor replacing it, so it'll be scrapped and I'll use the case. A couple of questions though:
    1: I've read some places saying that the MS-6340 used Pentium III CPUs, and some that have said it's a Socket A board. Were there two different socket versions of it? I don't know what mine is for sure, as it wouldn't get close to POSTing, let alone display anything on the screen on the standalone GPU (it doesn't have onboard VGA as far as I can see)
    2: How do I remove the heatsink from a Socket A system? I can't figure out how to and the levering/prodding I've tried so far has had no effect.
    3: It was fitted in an Evesham micro-tower case - is this motherboard original to Evesham? And if it is, what model could this be, as I cannot find a model on the case? (it has a Millenium Edition sticker on, if that helps)
    4: If you know the answer to 3:, is a FSP Group Inc FSP250-61GN(A) an original power supply for that machine? And is it actually any good, or is it a dodgy unit?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: MSI MS-6340 Rev 1 - epic capacitor failure
    1) the MSI MS-6340 is an early generation Socket A motherboard (AMD Athlon/Duron .. not Athlon XP).
    Manual is here:
    2) on the top side (where the 2 puking caps are) there should be a slot in the spring thingie to insert a flathead screwdriver. Push down on it and lever it (the screwdriver handle) towards the middle of the heatsink, so it unhooks from the pin(s) on the socket. You can lift it up and out of the way then.
    3) they probably used off the shelf components (i.e. MSI board you could buy anywhere back in the day) to build the system.
    4) No idea if it's original. Fortron Source (FSP) powersupplies are generally OK, as long as the caps are good. Some of those PSUs cooked them to death, some used a mix of mediocre and crappy caps (Teapo and Jamicon respectively)
    edit: old video on how to remove the heatsink (and other related stuff)
    http://www.youtube.com/watch?v=xfhb8pdwMYI
    • Lukeno94
      • Feb 2012
      • 6
      Thanks! The caps did look good when I took it apart, so it'll probably be worth keeping as a spare in case I come across another pre-P4 machine. I'll work on the heatsink some time soon.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        The caps in the pic you attached are all junk except the Nichicon HD (the sillver cans with the printing on top)
        typical for MSI at the time.. less than 5 good caps, rest off-brand crap.
        edit: oh wait nevermind .. thought you were talking about the board .. not the PSU lol
        If it has a 4pin P4 plug (yellow/black wires), it'll probably work for a low end P4 or Athlon XP machine.. Anything newer or beefier would probably overtax that grandpa of a PSU
        • Lukeno94
          • Feb 2012
          • 6
          It doesn't have a ATX12V connector, otherwise I'd have already tested it And it doesn't really surprise me that the caps are junk, they're the first bad caps on something I have owned, however.
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            MSI that vintage are usually pretty shoddy IME - bulging capacitors most likely GSC or CHSSI
            Argument in favour of fixing is non-ROHS construction, meaning capacitor removal & replacement relatively easy compared to ROHS
            All MS-6340 are SocketA judging by http://www.msi.com/service/search/?k...0&type=product - I found it necessary to select Detail Specification, because Basic Specification came up all N/A on some of them
            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
            • Lukeno94
              • Feb 2012
              • 6
              The caps around the CPU socket are Lelon 6.3V 4700uf 105 degrees units. The smaller green units are Tayeh 6.3V 1000uf 105 degrees, the largest black cap is a Tayeh 6.3V 2700uf 105 degrees, and the smallest black caps are also Tayehs. Those all seem like crappy brands to me, the metal cans being the aforementioned Nichicons are the only decent things on it.
              Strangely, there seem to be abnormally small screws connecting it to the baseplate of the case, which I can't seem to fit any screwdrivers in to (see the picture, an example is behind the two top big green caps), any ideas?
              And the processor turned out to be a 850MHz Athlon.
              • everell
                • Jan 2009
                • 1514
                I still have a working MSI 6330 (also known as K7T Pro). I kept it because it has a four LED array in the back which blinks out the post code as it boots. Mine has three sockets for memory sticks for 1.5 gig total. I don't remember what speed cpu it has, but it still runs fine. As I recall, I did have to replace some bad caps. But I think it is a unique board having the post tester on it.
                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                • Lukeno94
                  • Feb 2012
                  • 6
                  Well, the MS-6340 is much more of a budget model. It has 2 memory sockets (meaning I could run 1 GB with the two 512 MB PC133 sticks I have), and no POST LEDs on the back. The unit had clearly been stood for some time - two dead spiders were inside, along with several cobwebs. With 3 machines as it is, plus a fully-functional motherboard sat in a box, I can't justify recapping this board - as pretty much all the caps are junk brands, even if they aren't yet bulging.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5072
                    • New Zealand
                    You could always recap and sell the extra ones
                    -David VanHorn
                    • everell
                      • Jan 2009
                      • 1514
                      Just got a K7T Pro2 which is a variant of the MSI 6330. I notice that it has a handful of capacitors (two of which are bulging) with brand name Chhsi. Anyone have any idea who makes them? The rest of the capacitors are KZE, no other brand marking. Looks like I will have to do some recapping. This mobo has the post LED array in the back of the board so I think it will be worth saving. I found a 1 gig Thunderbird processor for it, but so far no heat sink/fan.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5072
                        • New Zealand
                        Chhsi are made by Chhsi - but I think the company has gone now.
                        I have the datasheets up here and you can find the rest of the site on the web archive.
                        -David VanHorn
                        • MORETTIGIAN
                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                          by MORETTIGIAN
                          Title:
                          Description:
                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                          Procedure performed:
                          - Removed backplate
                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                          - Reapplied thermal compound
                          - Reassembled card
                          Observed behavior after reassembly:
                          - GPU powers on and operates normally under...
                          09-18-2025, 12:14 PM
                          12/24 volt compressor cooler box inverter capacitor failure
                          by sam_sam_sam
                          This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
                          Found a 47uf@63 volts double the ESR value of a new one
                          The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
                          The main filtering capacitor was not replaced because I did not have that was not too tall
                          Where the 220uf capacitor is some type of switching power...
                          08-30-2022, 05:28 PM
                          DVR camera recorder switching power supply capacitor failure really
                          by sam_sam_sam
                          These cheap non brand capacitors at it again
                          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                          Well at least I have the cameras back on line I to try the...
                          01-22-2022, 06:28 PM
                        • Prolog
                          RTX 3080 FE Identifying capacitor
                          by Prolog
                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                          I hope these photos make it clear which component I am referring to:
                          (yes, the soldering is a bit botched from removing the blown one, I know)
                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                          12-01-2024, 08:27 PM
                        • Agent24
                          Dick Smith Q-1760 linear power supply filter capacitor question
                          by Agent24
                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                          It has at least one problem.
                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                          I have already ordered a replacement potentiometer, so that's not an issue.
                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                          All are CapXon...
                          10-21-2025, 05:39 PM
