Capacitors for Dell 400 SC .... purchased 2004
  • andyroman
    • May 2006
    Please guys I need the type of capacitors I need to replace ..silly capacitors.. going to do it .. I have 2 scs to work on
    Thanx
    ANdy
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Capacitors for Dell 400 SC .... purchased 2004
    what are the values? They should be printed on the jackets of the caps.
    Ludicrous gibs!
    • andyroman
      • May 2006
      Thanx,
      I will first thing tomorrow... so late finally found out the faulty capacitors after troubleshooting my computers.. so frustrating ..cheap parts....you think badcaps has most the capaciters?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • Mots06
        Old Dell E5400 Laptop ( Purchased in the year 2008)
        by Mots06
        Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
        07-19-2025, 01:56 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
        Dell Thunderbolt Firmware
        by SMDFlea
        Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
        Some models have a choice of 2 different firmwares, it depends on the dell SKU.
        The SKU is in brackets (****)
        EDIT: NVM65...
        01-26-2025, 06:22 AM
