Abit vp6
  • waynewrk
    • Mar 2006
    • 11
    Abit vp6
    Typical bad cap syndrome...I sent the board back to abit over a year ago not knowing anything about bad caps, just as a defective board. They sent it back to me un-repaired saying they couldn't find a problem with it. Several months later I stumbled onto this website from an ebay auction, and realized that bad caps were the problem. Abit issued me an rma for $25 or something like that with the caveat that it would take a while to get a replacement.
    Eight months later I figured they had long enough and tried to contact them about the status. I still have the rma number, but emails, and phone calls go unreturned. I finally gave up, and am shopping for a replacement. Just wondering if anyway else has had similar experiences with abit. I know they sold a lot of boards with bad caps pretty much all the vp6s from what it looks like. I was hoping maybe someone had insider info on how to contact a real person at abit? All I can get is email and voicemail which as I said have gone completely unreturned...
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Abit vp6
    8 months!? Good luck! I doubt they still have your board, or if they do, they have no clue where it is.
    Ludicrous gibs!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Re: Abit vp6
      last VP6 I RMA'd, they couldnt replace. The board was truly cooked. They called me and told me to go to their site and pick out a new in-production board, and they'd send me a full retail boxed version. Got a free IC7 Max3 out of that. The whole thing took about 3 months, they weren't speedy by any means. That's my last experience with Abit.
      As for yours, I think its LONG GONE.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • waynewrk
        • Mar 2006
        • 11
        Re: Abit vp6
        Yeah, I figured I was out of luck...So anyone have a vp6 for sale? Preferably one that is already recapped
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • ziplock
          Abit BE6-II motherboard
          by ziplock
          Greetings,
          I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
          I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
          04-20-2025, 02:09 PM
        • jagiro84
          Alienware x15 R2 no memory detected (hell repair job, 6 months later)
          by jagiro84
          Hi guys,
          its been around 5-6months since i left this board on side to rest my brain cells and now came back to try and repair it again.
          The laptop in question has issue where it gives error code on power on which is 2red and 3 blue
          In short, by Dell specs this means "Memory not detected: "
          Now one important thing the laptop would turn on fine when i leave it in the refrigerator for 5-10min and i could work\play games with it for days and months as long as i dont turn it off
          but after a while this trick stopped working as wel
          12-29-2024, 05:05 AM
          ABit IP35 Pro Motherboard Schematic
          ABit IP35 ProABit IP35 Pro Motherboard Schematic
          A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
          10-31-2024, 02:06 PM
        • tbalint3
          Abit ST6-Raid repair
          by tbalint3
          Hello All,
          I am trying to repair an old Abit ST6-R motherboard.
          The symptoms are the following:
          I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
          It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
          If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
          09-01-2024, 10:03 AM
