MS-6701 OEM for Medion MD5000 aka Titanium MD 8000 XL
  • Kiwi
    • Feb 2006
    • 24
    Re: MS-6701 OEM for Medion MD5000 aka Titanium MD 8000 XL
    I have two sticks of 512 MB RAM so I have taken one out and I am running the memtests on a single stick. I do not have another computer that will take the same memory but I can resort to sending it to my brother to test.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Originally posted by Kiwi
      There is no provision in this OEM (Medion) BIOS to alter the memory timings.
      At approximately 3 PM US CST my sytem had a BSOD and "stop error" with an "IRQ_NOT_EQUAL..." message, so things are not rectified. I am ready to throw in the towel on this motherboard and purchase a more recent one that is directly supported so I can be assured of support and adjustment.
      You shall run Prime95 to test the CPU!
      It Prime95 fails, it's definitely time to throw in the towel!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Kiwi
        • Feb 2006
        • 24
        the memory tests produced these results;
        1. I could run either 512 MB stick in either slot and no errors occurred.
        2. With both sticks in the system errors occurred.
        So I can try two things;
        1. Running with only 512 MB to see if I don't have any system crashes. This would take me 2 weeks before I could safely conclude this has eliminated my system crash problems.
        2. Send my memory to my brother, whose system is identical, so he can run the memory test with both sticks.
        I will do the later as it is much quicker.
        • gonzo0815
          • Feb 2006
          • 1600
          If you have gotten those bad swissbit trash ram, than i think you can trash it without further examination. Ii you are under waranty, then Medion will replace that crap with nice Samsung tccd like Rams (think they are knowing to sell crap). i have observed very bad experiences with thos cheapo rams from Medion. Even memtest haven´t found any error, but all 3d aps had benn locked up . So after replacing the 9800 gfx i got soome new Ram and ist worked. The service is ivery good from medion in germay, so but the Systems aren`t build to work too long (bad ram, slightly underpowered PSu with bad caps, no case ventilation and high temperatures on HDD, videokart and rest of the system.
          • Kiwi
            • Feb 2006
            • 24
            Originally posted by gonzo0815
            If you have gotten those bad swissbit trash ram, than i think you can trash it without further examination.....
            I am sorry I don't follow your post other than your point about bad RAM. I purchased the RAM myself and replaced what was originally in the system. I think it originally had a single 256 MB stick and I added another 256 MB right after I purchased the system (Nov 2002) then replaced the 2 x 256 sticks with 2 x 512 sticks about 18 months ago. I only started having the BSODs about 6-8 months ago so I cannot point the finger at the memory especially given the testing I did that is detailed in a previous post. I have been operating with a single 512 MB stick for 2 days and running my CPU at 100% and have had no problems. On Medion's support website they talk about having to use memory sticks that have no more than 16 memory chips
            Originally posted by Medion USA support
            Symptoms
            Installing 2GB of RAM (using two 1GB DIMMs of any speed) may result in your system becoming unstable.
            Cause
            The motherboard in your PC does not support DIMMs with more than 16 memory chips. The motherboard does not have enough power to drive the signals that operate the memory chips when more than 16 chips are on each DIMM.
            Resolution
            To use 2GB of RAM you will need to obtain 1GB DIMMs with memory chips that are at least 512Mbits (64MB) in size.
            My sticks only have 16 memory chips on them so I should be ok but given the problems and the result of the memory tests I have run I believe I am experiencing the same symptom as what Medion states when using 2 x 1 GB memory sticks.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              #26
              i am curious about this ram issue. is there any cap on the board 330uf and above which you did not replace?
              the ram worked ok before right, so should again once the issue is solved.
              • Galvanized
                • Mar 2006
                • 468
                #27
                Kiwi, GalvanizedYankee here. I signed on here as Galvanized.
                I was having RAM instability when case temps were below 17C (garage office) and realized the 3.3v line would drop to 2.5V when cold. Once the PSU's caps warmed up it was OK. This is not your difficulty ATM Tex but brings me to the point of a VG PSU replacement. There are a number of Enhance units at eWIZ.com that are worth considering.
                http://www.ewiz.com/detail.php?name=PS-EN5240G
                http://www.ewiz.com/detail.php?name=PS-EN5246G
                I realized both might be overkill but Enhance is a VG name in PSUs. For detail spec go to enhanceusa.com. There are others listed at eWIZ.
                I have an old but new 400 watt Fortron that's only been used for bench testing fans. PM me at anand if your interested. $30 shipped.
                Good luck on your current problem.
                ...Galvanized
                Willawake, if I've fudged on the forum rules, delete as requiored.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #28
                  dont worry. i would also like to see trial of another psu. but anyway i am still confused at the moment with this one. perhaps there is some cap near the ram slots bad? it could be an issue with power to two slots at the same time but i am not sure, any new psu should be able to do that.
                  anything else you want to sell put it in the for sale section, everything seems to go fast.
                  • Kiwi
                    • Feb 2006
                    • 24
                    #29
                    Yes, there are 2 x 470 uF capacitors (Teapo 16V) that I didn't replace based on what I read in this forum.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      #30
                      i say replace them. you can use same or 1000uf 16v.
                      • Kiwi
                        • Feb 2006
                        • 24
                        #31
                        I will and thanks for your advice. Can you tell me why you think this could be what is causing my memory errors.
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          #32
                          where are they located exactly? in the top half of the board?
                          in this situation i would replace all caps 330uf and above, in case there is a problem with the caps below 1000uf. personally i believe ram/psu is not an issue therefore the board should either work or not work if the badcaps are removed, not have these kind of issues. if not then try another psu and test your ram on another computer before giving up.
                          please advise about the replacement caps used though. i am assuming appropriate caps were used.
                          • Kiwi
                            • Feb 2006
                            • 24
                            #33
                            looking at the board as it is in the case, which is mounted vertically, the 2 470uF capacitors are on the lower third of the board. The memory slots are in the upper right portion of the board.
                            I used Rubycon capacitors, not knock offs either.
                            I have used three PSUs;
                            1. the original that was in the system when I bought it (FSP250-60MDN). This PSU was definitely going downhill as it was generating copious amounts of heat. When I opened it up it had three bulging capacitors.
                            2. A 250W Channel Well PSU (bought from CompUSA, packaged as Master Power, labelled as Norwood Micro, manufactured by Channel Well Technology).
                            3. An Ultra ULT31840.
                            I ran the memory tests with the Channel Well PSU, so I will run the test with both sticks of memory in place with the Ultra PSU.
                            I will send the memory sticks to my brother to test after this weekend.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              #34
                              then they will probably not affect the memory circuits. i think your ram will test ok at your brother's if each stick tests ok by itself but not together. if you get similar results with the new psu then there is a possibility a trace or via on the board got damaged during the recapping. this happens sometimes. its not for the trash though if you can determine which memory configuration with the various slots produces no errors then you will have a stable configuration that you can use.
                              • Kiwi
                                • Feb 2006
                                • 24
                                #35
                                I had to get a case fan yesterday so while I was in the computer store I took a look at memory. There were 512 MB sticks of DDR (PC3200/400MHz) for $20, after rebate. I thought, what have I got to loose? I purchased two sticks and ran the memory test for 14 consecutive hours over the evening and this morning.
                                NO ERRORs!!!!!
                                I am very happy with this result and will run my system for the next 2 weeks to see if it is stable under Windows. If it is then I will consider my problem solved. The RAM I took out has a lifetime warranty so I will send it in for replacement.
                                • willawake
                                  Super Modulator
                                  • Nov 2003
                                  • 8457
                                  • Greece
                                  #36
                                  GREAT news, i am glad it worked out for you.
                                  • Kiwi
                                    • Feb 2006
                                    • 24
                                    #37
                                    Somewhat of a nagging thought is that it could have been a memory problem all along and I went through all the hassle of purchasing and replacing my capacitors for little actual result.
                                    My power supply was definitely in need of replacement so I was glad that came out of this effort.
                                    • willawake
                                      Super Modulator
                                      • Nov 2003
                                      • 8457
                                      • Greece
                                      #38
                                      if they were badcaps then they wouldnt have lasted forever anyway. now you will be fine for a while.
                                      • Kiwi
                                        • Feb 2006
                                        • 24
                                        #39
                                        three days of my computer running without a BSOD!!!!
                                        I have sent my old RAM to my brother so he can run the memory test on those 2 sticks in his Medion.
                                        • realdeal
                                          • May 2006
                                          #40
                                          hi guys
                                          was doing a google and came a cross u.
                                          have been looking @ a new PSU for my medion md 8000/MS6701 , current psuFSP250-60MDN-120
                                          is this ok dimension wise
                                          http://www.komplett.co.uk/k/ki.asp?sku=308622
                                          i need extra power so i can attach radeon 9800pro g/card as it needs its own supply.
                                          many thanks
                                            HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                            09-12-2024, 03:44 PM
                                            HP Compaq Elite 8000 SFF Compaq Elite 8000 E5700 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Elite 8000 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8000 SFF boardview and Compaq Elite 8000 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo ThinkPad X1 Titanium Yoga Gen 1 Hybrid (2-in-1) X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Titanium Yoga Gen 1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Titanium Yoga Gen 1 boardview and X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-07-2024, 04:30 AM
                                            Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-07-2024, 04:10 AM
