biostar u8668-d
  • mrjeep88
    • Nov 2010
    • 10
    biostar u8668-d
    Hi guys I recently got a biostar u8668-d motherboard from a friend. He said it was working and he left it for a little while and when he came back the computer was off when he turned it back on it would power on and not post. He just swapped out the board and gave me the old one. It had two blotted caps beside the cpu so I replaced them with the exact size as the old ones and still no post. so could I have more bad caps that aren't showing on top or bottom or could it be a fried board
  • brethin
    • Dec 2008
    • 1907
    Re: biostar u8668-d
    The other caps could be bad, they don't have to be bloated to be bad. And yes it could be something besides bad caps.
    • mrjeep88
      • Nov 2010
      • 10
      Re: biostar u8668-d
      thanks I was wondering if the caps could be bad and not showing. now for another question can I check the caps with a digital multimeter or do I need some other tools. I have never checked caps before only changed out the bloated ones. any advice would be appreciated
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: biostar u8668-d
        You either need an ESR meter and a uF meter or to ask old farts.
        Did you use low ESR caps for the new ones?
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: biostar u8668-d
          When you ask about caps list: make, series, uF, volts, and diameter in mm.
          - Dr Seuss
          • mrjeep88
            • Nov 2010
            • 10
            Re: biostar u8668-d
            ok so I will need more tools. The caps are kzg 6.3v and 3300uf at least those were the ones the bloated the other caps are g-luxon 10v 1000uf there is also two kzg 16v 1500uf. The two I replaced I used ost 6.3v 3300uf that i had laying around left over from recaping another board
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: biostar u8668-d
              See, that's why asking old farts helps...
              KZG are prone to failing without bloating, just replace all of them.
              KZJ does the same thing. - Cases of bad series in an otherwise good brand.
              G-luxon usually bloat but they are crap so just replace those too.
              Unfortunately OST behave a lot like KZG.
              Might get you going for now but for how long is questionable.
              - Dr Seuss
              • mrjeep88
                • Nov 2010
                • 10
                Re: biostar u8668-d
                thanks I will replace all the kzg and see if it boots. If it does then I will order all them in a good brand. any advice on a good brand cap
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: biostar u8668-d
                  For KZG:
                  Rubycon MBZ, MCZ
                  Nichcon HM, HN [but not w/ 2001-2004 date codes]
                  Sanyo/Suncon WG
                  Panasonic FL, FJ
                  NIC Components NRSK, NRSJ [Don't confuse NRSK series with NRSK brand.]
                  Samxon GD, GC
                  - Dr Seuss
                  • mrjeep88
                    • Nov 2010
                    • 10
                    Re: biostar u8668-d
                    thanks I just changed out the last kzg 6.3 3300uf as there were only two of them left and powered the board on and it posted fine so I will be ordering some new caps from the list you posted. thanks for all the help
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: biostar u8668-d
                      With those that are Vcore caps you could also do a poly upgrade.
                      I don't think the cost would be much different anymore.
                      - Dr Seuss
                      • mrjeep88
                        • Nov 2010
                        • 10
                        Re: biostar u8668-d
                        I might do that I am useing the board in a computer that I am building for my sister to do her school work on so it needs to last and if poly will last longer then I will go that way as I am sure she will be playing games on it like world of Warcraft.
                          by momaka
                          03-12-2025, 03:42 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
                        • Foetuss
                          Gigabyte GA-6OXT :: caps question
                          by Foetuss
                          Good evening
                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                          But I was also suprised about the bigger boys, which are 330µF 25V.
                          Could it be they used 25V caps because they were cheaper / available at that time?...
                          02-11-2025, 12:22 PM
