Asus A8V-Deluxe Cap ID
  • Axis
    • May 2011
    Hi All,
    I have an Asus A8V-Deluxe Rev 2.00 board with a couple of bad caps.
    Not my picture, but the 2 just below the LPT port, on the right side, are bulging. The 2 to the left look to be the same, but are not bulging. I can't pull the board right now to read them. The system is still running, but reboots randomly, which is causing all sorts of production issues.
    Does anyone know what capacitors I need to order to replace those?
    Axis
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Asus A8V-Deluxe Cap ID
    You need to replace more that just the bulged ones.
    Asus uses a far more than one problem cap -and- they don't always use the same caps even on the same model of motherboard.
    So:
    What caps someone else has [or had] on their A8V-Deluxe might not be the same as what you ended up with on your board and thus you might need a completely different set of replacement caps than they did.
    If you are trying to order caps without evaluating what is actually on YOUR board then you will need to order a replacement for every cap over 6.3m diameter to ensure you have the proper caps on-hand when you do get it out.
    If you don't you may end up having to wait on a second order of caps before you can finish the board.
    Mann-Made Global Warming.
    - Dr Seuss
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • DynaxSC
      ASUS STRIX Z490-F GAMING - No POST, stubborn board
      by DynaxSC
      I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
      The situation looks like this:
      After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
      1. RTC oscillates normally (32.768KHz).
      07-08-2022, 05:45 AM
    • ShadowAi12
      ASUS ROG STRIX B550-F GAMING — Board not powering on properly
      by ShadowAi12
      I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
      • The board enters a "ready to power on" state after plugging in the PSU.
      • Pressing the power button increases power draw.
      • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
      Measurements:
      (taken after pressing the power button, while the board is attempting to start)
      • H_SKTOOC#
      06-11-2025, 01:05 PM
    • jimbodriver
      Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
      by jimbodriver
      I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
      Initial results:
      Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
      03-20-2022, 02:30 PM
