Hi, recently, my 7800GTX has been showing extremely garbled pictures. Initially when this problem started ,the card refused to output video when using DVI-D, but with a DVI>Analog converter I was able to get video (but extremely garbled). I was desperate and flashed it to a 7800GT. I now get output on the DVI, but the image is still extremely garbled. I'm wondering if there's any possibility that I have bad caps. I've attached pictures of the 4 cylindrical capacitors my card has. Thanks in advance
Possible bad caps on 7800GTX?
Tags: None
Re: Possible bad caps on 7800GTX?
argh, I just realised I put this in the wrong forum
, can a mod please move it to "Identifying Bad Capacitor Problems" for me?
Well I would RMA it, BUT (here's where I really feel stupid), I misplaced the cover for the heatsink that guides the airflow through the fins. I initially took it off, because I mounted a fan underneath it which reduced the cards temperatures by 20*C. So unless I can aquire the faceplate to an MSI gtx, or somehow find mine, I can't really RMA it.Comment
I gather by 1 of your other posts that you o/c. Did you push the GPU, Mem or AGP buss a bit too far? You reflashed the bios to a lesser spec and that seemed to help a bit. Have you tried to underclock the GPU and/or memory to see if the problem diminishes moreso?Comment
I don't think its either mobo or PSU, because my 12V rail stays at 12.00V-12.01V even on full load (I checked this with a DMM), and the video card I'm using currently (an X800Pro) has no problems whatsoever. Also I had a friend test my 7800gtx and he had the same symptoms. My PSU is an OCZ PowerStream 520W.Originally posted by linuxguruIt's probably not a capacitor problem on the card (the caps look OK), but it could well be a PSU or motherboard cap problem causing poor voltage regulation. Check the PSU first.
I do OC, the videocard is PCIe, and I didn't touch the PCIe frequencies. I did have the card clocked to 500/1390(430/1200 is stock, 7800GT is 400/1000). I would try reducing the frequency farther, but I have trouble navigating windows with the way the video card currently outputs video.Originally posted by MustangI gather by 1 of your other posts that you o/c. Did you push the GPU, Mem or AGP buss a bit too far? You reflashed the bios to a lesser spec and that seemed to help a bit. Have you tried to underclock the GPU and/or memory to see if the problem diminishes moreso?Last edited by TerraPhantm; 02-07-2006, 12:53 PM.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
