8800 GT with bad caps, i think
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: 8800 GT with bad caps, i think
    The one on the right maybe.
    Given the bloated ones I wouldn't trust any of that -brand- to be good on that board.
    Either a bad batch or something happened on/to the board that they couldn't handle.
    Mann-Made Global Warming.
    - Dr Seuss
    • letterpost
      • Mar 2011
      • 14
      i can't believe it, I CAN BELIEVE!!!!!!!!! I FIXED IT!!!!!!!!!!!!!!!!!!!!! IT IS WORKING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      I have replaced all capacitors (except the small ones) the shorted transistor and I cooked the PCB again just in case, and it worked.
      I still cant believe it!!!!!!!
      Thanks PCBONEZ thank you very much.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Did you cook it with the caps off?
        Ludicrous gibs!
        • letterpost
          • Mar 2011
          • 14
          yes, i just leave the caps I was gonna replace.
          the only problem now is i cant put back the cover of the heatsink, the new caps are too big and i cant get anything smaller here, maybe if i put them in the back of the PCB it will fit back in. I´ll see how it goes.
          for now is 1:21 hs with same overclock and no cover.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            CONGRATS:
            Hey, I found the data sheets...
            Bottom of this page mentions "Samcon-Elcon"
            http://www.tw-elcon.com/en/index.php
            Which takes us here...
            http://www.samcon-hk.com/
            To see the data sheets...
            EPL is here:
            - Dr Seuss
            • letterpost
              • Mar 2011
              • 14
              #26
              well, samcon electrolytic cap is exactly what i got.
              i think is this.
              i couldn´t found caps for the 16 v 180 uf so i replaced them with 16 v 220 uf samcon. all electrolytic.
              yes, "they said i was maaaaaaaaaaad, but it works.... It WORKS!!!!" the board now is my own frankenstein. lol
              anyway, achieved 10 hs overclocked on atitool. but after that sometimes i experienced some suddenly screen black out and must reboot. thats strange because that only happend when the pc is in use and the atitool full on. i think it maybe the thermal die monitor shutting down the gpu for extreme temp. works fine overloaded with atitool but can´t handle any more windows work. seems the driver i use is not compatible with the atitool i got because i cant see the temp, happened before.
              perhaps the problem is the cover out of the heatsink, do you think it will be the same if a install the caps in the back side of the pcb? that way i´ll have room to put the cover back on and maybe the heatsink will work as it should.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                If:
                ... You have room for the caps that way
                ... You make sure to get the polarity right
                ... There is enough of a solder pad there
                then it should work.
                Caps in your photo are EPL series, not EEZ.
                That's why the say EPL on them.
                If you click on 'products' in the page I linked to it brings up this.
                http://www.samcon-hk.com/Products.as...on=next&page=1
                Their caps list is 9 pages long.
                - Dr Seuss
                • letterpost
                  • Mar 2011
                  • 14
                  #28
                  Hi pcbonez,
                  I see what you saying. please have patience, i´m not an electronic engineer, i just like this but it is hard.
                  I choose EEZ on the link because that is what it looks like the one i got, but i really dont know for sure, all i know is it is not solid elcon EPL and it is not solid at all, i´ll take another look to the cap to see what it is. in the store i showed them the card and ask for something to replace those.
                  So if the black out problem is because of the diference in the specifications of the caps or in the transistor im pretty much in the same place, just with one step forward. i had 2 more black outs since the last post and NOT using the atitool. my next try will be replacing the drivers (unlikely), if that doesnt work I´ll give a shot to the link you give me here in argentina.
                  One think that keeps me thinking is why it hold ten hour at full load on the atitool without a blackout, and using it i just got 2 in less than an hour.
                  another chance is a bad cooking. lets see.
                  Again, thanks for your help and patience, i really appreciate it.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    When you say EEZ you mean some you say in a store??
                    Look up the old caps in their data sheet.
                    You want caps with the same or less ESR.
                    - Dr Seuss
                    • letterpost
                      • Mar 2011
                      • 14
                      #30
                      I mean in the store, the only caps they got in there were those that i put in the card, no matter ESR, those were the only ones, in others stores is the same the only thing that changes is the manufacturer but same values for the caps
                      anyway nevermind, i found the problem, is the transistor and i don´t think i would be able to found a replacement here.
                      Thanks for your help.
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
                        XFX GeForce 6800 XT AGP [PV-T42K-UDE3] – recapping and mods
                        by momaka
                        Aaaaand… we have more retro-PC nostalgia repairs again.
                        This time it's with a XFX GeForce 6800 XT AGP video card. The XFX model number is PV-T42K-UDE3.
                        As with many early XFX cards, crap caps are the main issue here. The first one I bought and recapped was back in 2017. I've been meaning to post about it for a long time, but never got around to it due to the card needing a better heatsink/cooler to test it fully with the recap (more on that later on.) In the meantime, I acquired a 2nd one of these cards not too long ago (February.) Not like this makes any difference. Both...
                        07-25-2020, 02:51 PM
                      • black6host
                        Replacement caps for Samson Resolv studio monitor 65A Amp board.
                        by black6host
                        Good day!
                        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                        I'm going to replace the caps and I'll be the first...
                        02-06-2024, 08:22 PM
