Epox EP-8RDA+
    Re: Epox EP-8RDA+
    In the process of taking a close look at all the caps on the board to make the list above I ran across a capacitor that I could hardly read. Turns out it was baked so bad that it was almost black. Against the advice I got from you guys, I replaced it with another of the caps from the old K6 board and Viola! Perfect working computer (so far).
    I'm installing windows xp media center on it right now so we'll see if I screwed anything up. USB doesn't seem to be working, may be a driver issue.
    There are still 4 Noticeably bad caps left on the board that I need to replace (the 2200uf 10v GSCs). I'm going to try to find those locally so I dont have to spend as much on shipping as the caps.
    I feel pretty good about actually being able to repair a motherboard though, even if I did go the Po-Boy route and haven't spent a dime on it so far. Couldnt have done it without this site though. =)
    Doc
      Re: Epox EP-8RDA+
      Thats encouraging progress. Those 2200u caps are at the input to the VRM, failure could suggest higher than normal ripple from power supply. Have you checked the PS yet?
      Gigabyte EP45-DS3L Ultra Reliable (Power saver)
      Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      160Gb WD eSATAII Server grade for backup.
      Samsung 18x DVD writer
      Pioneer 16x DVD writer + 6x Dual layer
      33 way card reader
      Windows XP Pro SP3
      Thermaltake Matrix case with 430W Silent Power
      17" Benq FP737s LCD monitor
      HP Officejet Pro K5300 with refillable tanks
        Re: Epox EP-8RDA+
        Its running on a different PS from when it went bad. I will be looking into the PS sometime soon though to do a checkup.
        Doc
        Also, I'm not positive, but I think I've determined the cap that causes the hang at C1 while trying to post. If anyone's interested in this feel free to contact me.
          Re: Epox EP-8RDA+
          Gotta love it.
          Sorry for the troubles. We can issue you rma repair,
          Your RMA number is 3060123982
          Please return your motherboard only to:
          Epox International Inc.
          Attn. RMA Department (with your RMA number outside the box) without rma number outside box our department will refuse the package.
          531 E. Jamie Ave
          La Habra, CA 90631
          Instruction:
          1. Please ship motherboard only and please pack well to prevent shipping damage.
          2. Please include a note with your return mailing address, description of problem and the best number to contact you.
          Without these information's your rma maybe delayed.
          3. Please ship with UPS, Fedex, or USPS with tracking number.
          4. Processing time is about 1 week, and board will be returned via UPS Ground.
            Re: Epox EP-8RDA+
            Doc; please post a pic of that cap you talk about...
            I only changed the "big" caps on my Epox board... It's working fine but I might think twice about selling it if the smaller caps go bad too...
              Re: Epox EP-8RDA+
              Doc is in the USA, he should get caps from Topcat.
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
                Re: Epox EP-8RDA+
                Re the toasted cap. Have you checked the supply voltages in the hardware monitor section of the bios? The cap may have overloaded a voltage regulator.
                Nvidia 8500GT 256Mb
                33 way card reader
                Windows XP Pro SP3
                  Re: Epox EP-8RDA+
                  All the voltages, before, and after the half-assed recap I did were very close to where they were supposed to be.
                    Re: Epox EP-8RDA+
                    The cap that finally did the trick was a 1000uf 6.3v cap. I marked it best I could in this picture.
                    It looks like even in this picture it's a bit of a darker color than its sisters. This isnt an actual picture of my board, but I bet you this guys' has been cooking too.
                      Re: Epox EP-8RDA+
                      The reason it could post 5 times in a row and then later not at all is because when the caps become warmer they actually work better ...
                      When lytics are hot, their capacitance is much higher, and their impedance is lower. For example, a 1000uF, 50V FM I've been torturing:
                      At 77C case - 961uF, 11.6 milliohms;
                      At 21C case - 879uF, 16.1 milliohms.
                      PeteS in CA
                        Re: Epox EP-8RDA+
                        Cool Petes, I guess that test prooves that it is not really that important what farad rating the replacement cap has, as long as it's not crazily off. Since the circuit is prolly designed with quite a bit of tolerance in mind..
                        That is contrary to what most people say I mean...
                        And Dood; thnx, I thought you meant the smaller 470uF and below caps... I have already changed all big caps on my Epox, i.e. 1000uF and up... (since they where all bulging LOL)
                          Re: Epox EP-8RDA+
                          Lytics are +/-20% components - that is the significance of the "(M)" on Nichicon HN(M), etc. Cores used for filter inductors are usually +/-20% or +/-30% tolerance parts. So, yeah, compensation in regulators is designed to accomodate these loose tolerances.
                          PeteS in CA
