I'm working on trying to recap a Dell GX620 SFF PSU. (After recapping the board with a badcaps kit) There were two failed caps (bulging tops) inside the PSU.
I removed the caps (can't see any of the printing on them, it's so jammed together), found datasheets and got subs for everything except:
Ltec LZP series, 2,200uF - 16v - 1.925a ripple - 0.040ohm impedance, in 10x28mm size
I searched digikey and mouser, and they do not seem to have anything in 10mm diameter with that high a ripple rating; they are all 12mm diameter.
The design is ridiculous inside this PSU, they caps are all snuggled together so I do not see any way to get a 12mm cap in there.
The offender:
Also, for reference here are the other subs: (Larger caps only, I'm leaving the little ones alone)
A- Teapo - SC - 2200 - 10- 10x20 - 1.330a - 0.047ohm
A- Panasonic - FC - 2200 - 10 - 10x30 - - 1.815a - 35mohm
B- Ltec - LZP - 2200 - 16 - 10x28 - 1.925a - 0.040ohm
B- <still looking>
C- Ltec - LXY - 1000 - 10 - 8x15 - 1.300a - 0.040ohm
C- Panasonic - FM - 1000 - 10 - 8x20 - 1.56a - 30mohm
D- Teapo - SC - 220 - 35 - 8x15 - 0.730a - 0.100ohm
D- Panasonic - FM - 220 - 35 - 8x15 - 1.24a - 41mohm
The offender:
B- <still looking>
