need a lil advice on recapping ECS HP MCP61PM-HM
  • netimports
    • Nov 2010
    • 13
    I got about 4 of these boards that need to be recapped. On all four its the same caps, 9 of them bulged up.
    TK 6.3v 1800uF
    Now the boards have another 3 caps:
    TK 16v 1800uF
    the 16v's seem to look fine, no bulging or ooze.. Should I be replacing the other 3 caps since they are of the same brand?
  • bigbeark
    • Jan 2010
    • 661
    Re: need a lil advice on recapping ECS HP MCP61PM-HM
    Yes, replace all caps of this brand. Look around this site you will find recommended caps: Rubycon, Panasonic (Sanyo), United Chemi-Con and Nichicon. Post a list of all the caps on the board, their uf and Voltage. People here will give you suggested replacements.
    • netimports
      • Nov 2010
      • 13
      thanks for the reply bigbeark, here is whats on the board:
      TK 6.3v 1800uF
      TK 16v 1800uF
      OST RLS 6.3v 1000uF
      G-LUXON 16v 470uF
      And like i said only the 6.3v TK's are bulged but i'll replace all the TK's, how about the other two OST and G-LUXON? and does the height matter when replacing them? I found these on ebay to replace the 1800uF TK's:
      OST 6.3V 1800UF
      Component Ratings
      Capacitance = 1800uf
      Voltage = 6.3V
      Temperature = 105ºc
      Mounting Type
      Radial Thru-Hole Snap In
      Dimensions
      Diameter = 8 mm
      Length = 20.5 mm
      Lead Spacing = 3 mm
      and Rubycon MCZ 16V 1800UF LOW ESR for the other TK's, is OST good enough to replace or should I go with one of the ones you suggested?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Is best to replace all of those you mentioned.
        Mann-Made Global Warming.
        - Dr Seuss
        • c_hegge
          • Sep 2009
          • 5219
          https://www.badcaps.net/forum/showthread.php?t=8053
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            ost, g-luxon, and tk are all low-quality. it is also not recommended buying capacitors off of ebay because they use 99% counterfeit. recommended are rubycon, samxon, panasonic, chemi-con, sanyo, and nichicon, along with a few others. here at badcaps.net he carries rubycon and samxon.
            • c_hegge
              • Sep 2009
              • 5219
              For the 16v TK caps, use these or these
              For the 6.3v TK caps, use these
              For the OSTs, use these
              For the G-Luxons, use these
              • netimports
                • Nov 2010
                • 13
                thanks a lot guys, lots of good advice given.. Does it matter if I get a 18mm or 20mm (height)? lead spacing, is that calculated by the diameter? and c_hegge the 16v TK caps you refer to.. the links has two different uF ratings.. the originals were 1800, the ones you link to are 1800 and the other is 330? and thanks for taking the time to drop those links.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  seems like a mistake to me. theres no reason to link to a 330uf cap...unless you want a broken computer
                  • netimports
                    • Nov 2010
                    • 13
                    alright thanks thats what i thought. This might be a stupid question but is there any reason why on all four boards the same 9 TK 6.3v 1800uF have bulged and the rest look ok?
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      are they right next to the cpu? then it is because of two things: 1. high-stress apllication, because they are part of the cpu'd vrm (voltage regulator)...2. heat. because it gets hot over there
                      • seanc
                        • Nov 2008
                        • 1319
                        Ah no, wait a second.
                        The 330uf capacitor is a polymer capacitor, as opposed to the original electrolytic capacitor.
                        It is common practice among people with more experience, to use polymer capacitors in the VRM of motherboards, since the bulk capacitance is not important (apparently).
                        One day I'll read an idiots guide as to why
                        • netimports
                          • Nov 2010
                          • 13
                          well they seem to be priced the same, so should i go with the polymer? i think the board has 3 polymers on it right by the bad ones.. can't tell what they are they got LF 820 ø 791 written on top.. and shovenose about 5 are situated around the cpu, 2 by the pci-e and 2 by the ram.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            the 330uF are solid polymer caps. When poly-modding, you lower the capacitance. I have poly-modded this exact model before using 470uF polys, but kc8adu said he's done it with 330s and it works.
                            Poly caps would probably be better for long term reliablility, and since this is a fairly new board, I would go for it.
                            The LF polys by the CPU are Nichicon LF. They can stay. On the board I re-capped, I replaced the 6.3v TK caps near the CPU with more LF polys and the others near the northbirdge and RAM with Panny FJ.
                            • netimports
                              • Nov 2010
                              • 13
                              so how do you tell what the ratings are on these LF's? If you say they are good for long term reliablity, I'd rather replace them all with poly's.. I can't find any 6.3v here for poly's..can you let me know what uF rating you replaced the 6.3v Tk's with and a place to get them from?
                              • c_hegge
                                • Sep 2009
                                • 5219
                                The second line on them. Those are 820uF. You don't need 6.3v caps in the CPU VRM out, since the voltage there is only the CPU Vcore voltage, which is less than 2v, so a 2.5v cap is ine there (which is probably all those LFs are).
                                • netimports
                                  • Nov 2010
                                  • 13
                                  so i can replace the 6.3v 1800uF's with the 820uF 2.5v poly's? as you can see my extensive knowledge of caps is overwhelming! I've stared at them and have even touched a few!
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    It will be fine with the ones near the CPU, but leave the others as electrolytics.
                                    • netimports
                                      • Nov 2010
                                      • 13
                                      will do, thanks for all your help
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        If CPU side of VRM [the 16v VRM caps] cap count is only three I would use the 470uF if going to poly. If you have 4 there 330uF is okay.
                                        - That is consistent with lay-out factory boards I've seen.
                                        Not much point in doing 16v side of VRM if you don't do the Vcore side too.
                                        - Dr Seuss
                                        • Gwynz
                                          First time recapping a motherboard, need advice!
                                          by Gwynz
                                          Hey guys, I just picked up an old Athlon motherboard (Chaintech 7AJA2) to build a vintage PC system around and noticed it had a leaking cap and a few others that appear to be bulging
                                          It does boot up fine though, just finished installing Windows XP and it ran through a few 3dfx demos successfully (using a Voodoo3 3000 AGP card) but it does seem to have issues when I have more than one stick of RAM installed, should I also change out the little squat capacitors that are around the DIMM slots even though they appear fine?
                                          04-04-2022, 11:44 PM
                                        • proxneo
                                          Recapping Sony ICF-SW55 - verifying cap values
                                          by proxneo
                                          Dear reader
                                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                          At the moment, I have selected replacements based on the following list of values:
                                          3 x 470uF 10VDC
                                          3 x 4.7uF 35VDC
                                          4 x 47uF 50VDC
                                          8 x 22uF 6.3 VDC
                                          1 x 220uF 6.3VDC
                                          5 x 100uF 6.3VDC
                                          Which...
                                          06-21-2023, 12:38 AM
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Green Probe
                                          Mosfet Advice
                                          by Green Probe
                                          Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                                          05-22-2025, 10:49 AM
                                        • user234
                                          Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                                          by user234
                                          Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                                          My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                                          I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                                          If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                                          This is...
                                          05-10-2025, 04:25 AM
