RX 5700 XT shorted power rails
  • ongobongo
    • May 2023
    • 58
    I just received a non working Powercolor RX5700XT Red Devil which I'm trying to repair.
    Card does nothing so I dissasembled it and tested for rails.
    12V is fine, as well as 5V and 3,3v.
    Problem is that 1,8V and 0,75V both dead short to ground (and to each other).
    I tried injecting 0,75V into the rails, but the only spot that is lightly glowing, although set to 3A, is a little spot on the edge of the APU-die.
    Am I right in assuming that the APU is dead and the card is for donors or did I miss anything?
    Ongo
  • madsay
    • Mar 2018
    • 8
    • turkey
    tespitiniz doğu gpu dead
    • Aliencomputres
      • Aug 2019
      • 208
      • România
      english only !
      • reessi
        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
        by reessi
        Hello:
        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
        I started on the ACER:
        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
        10-29-2024, 11:31 AM
      • chickenhawk88
        RAZER BLADE 15 2021 MODEL, No power, shorted rails.
        by chickenhawk88
        The laptop I am working on is RAZER BLADE 15 , RZ09-0369, the motherboard is DA560 VER 4.0. The original fault was it powered up with keyboard rgb on and no video on screen/hdmi. I found corrosion on memory module that leaked onto the memory socket. I cleaned the memory socket and was able to boot normal with other memory socket with good memory. I really should have stopped at this point as everything was working except for the one bad memory slot.
        I wanted to find out what was wrong with the other memory slot. I replaced a 330uf cap, a buck converter on back of board and when i...
        05-15-2024, 06:37 PM
      • Zakyn
        MSI GTX 1660 Super - all rails shorted?
        by Zakyn
        I received a broken MSI GTX 1660S, not detected in the PC. There is no short circuit on 12v and 3.3v. 5V is present. So I moved to 1.8V, and it's missing, so no other voltages will be there. Against ground I am measuring 0.0ohms on 1.8, PEX, VMEM and VCORE. Is it dead core, or Turing GPUs has that low resistances? And its possible that it burned in a way that all rails are shorted? As sanity check I removed GS9216 buck converter and replaced it with new one but still no 1.8V. Can anyone please confirm that I can put this GPU away?
        01-12-2024, 02:55 PM
      • Yanleb
        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
        by Yanleb
        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
        D608, good
        D618 RF101L4S, good (See warning 1 below)
        D619 RF101L4S, good (See warning 1 below)
        D865 RF101L4S, shorted (See warning 1 below)
        IC464 Inverter HA MC74HC1G14, shorted...
        03-09-2020, 12:00 AM
        AMD Radeon RX 5700 XT (RX5700XT) Schematic & Board View
        The Radeon RX 5700 XT is a high-end graphics card by AMD, launched on July 7th, 2019. Built on the 7 nm process, and based on the Navi 10 graphics processor, in its Navi 10 XT variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 5700 XT. The Navi 10 graphics processor is an average sized chip with a die area of 251 mm² and 10,300 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. AMD has paired 8 GB GDDR6 memory with the Radeon RX 5700 XT,...
        10-01-2024, 12:06 PM
