how to underfrequency ram on RTX3090 more than in Afterburner
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    how to underfrequency ram on RTX3090 more than in Afterburner?
    I have micron bad series and -500MHz on memroy was not enought to work ok
    best if i can bios mods it so it will stay
  • emil_t
    RTX3090 working fine but fans not spinning
    by emil_t
    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
    04-12-2024, 06:54 AM
  • Nellone93
    Asus Rog Strix RTX3090 Oc
    by Nellone93
    Hello, got cooler liquid on my card and this happened.
    I'd like to try to repair it, and ask if someone can help me with schematic.
    thank you
    09-04-2024, 02:43 PM
  • Nukes1810
    Dell RTX3090 board view (MSI v388)
    by Nukes1810
    i had to remove some resistors on the back to look for a short and they bounced off the table while looking for its value using a meter, i attached a pic of them, id trake the value of them if any one knows them but if therre is a board view it would be great as well since itll help me trace the short.
    Thank You...
    11-18-2022, 06:36 PM
  • Zyto9185
    Need Help with msi gtx 1060 gt6 OCV1 schematic
    by Zyto9185
    Hello Im new and I have a problem with a msi gtx 1060 6gt ocv1
    When I turn the pc on, after 5 - 15s the gpu will shut off and the fans will go 100%.
    The psu is not the problem because I have testet it in other pcs and it even shuts off in bios.
    I think the problem could be 5 capacitors missing on the back side,
    but I cant identify them because they are made of ceramics and are not marked in any way.
    The gpu Im talking about is this one: https://www.amazon.de/MSI-DL-DVI-D-A.../dp/B01KF90IY8
    But when...
    Today, 03:49 AM
  • alloverme
    HP 15-eh0001nf with a start issue
    by alloverme
    Hello, I have an HP 15-eh0001nf with a start issue,
    • First it didnt start at all power button blinking blue and no screen, but seems a boot loop*
    • I tried to remove most component - > same issueI see some little corroded component, clean them with isopropyle alcool and resamble all -> it worked during less than one minute and did the same issueI
    • tried to clean it again and worked few second and get same issue...
    • Now dont want to start anymoreI see on thermal cam a component getting a bit hot (qr=7j 13g) and didnt find any information about it (, i tested all rail and no short..ยต
    07-19-2025, 06:31 AM
