Need Help with msi gtx 1060 gt6 OCV1 schematic
  • Zyto9185
    • Oct 2025
    Hello Im new and I have a problem with a msi gtx 1060 6gt ocv1
    When I turn the pc on, after 5 - 15s the gpu will shut off and the fans will go 100%.
    The psu is not the problem because I have testet it in other pcs and it even shuts off in bios.
    I think the problem could be 5 capacitors missing on the back side,
    but I cant identify them because they are made of ceramics and are not marked in any way.
    The gpu Im talking about is this one: https://www.amazon.de/MSI-DL-DVI-D-A.../dp/B01KF90IY8
    But when I try to find boardviews of it I would find nothing.
    I did a little research and now I found out that the Msi Geforce P106 100 Mining for some reason is the same as the card i got
    but i thought mining cards dont have outputs. For the Msi Geforce P106 100 Mining I found a boardview(attached BoardView.pdf file) but sadly it doesent show the capacities of the
    capacitors. I also found a schematic(?) (attached SCH.pdf file) but I dont understand what it says.
    It would be great if someone could help me.
    Thanks in advance!!😊
