Gateway GT5240E recap
  • dwcrabtree
    • Oct 2010
    • 7
    I have a Gateway GT5240E desktop motherboard that needs a recap.I looked inside and sure enough there are 7 caps around the processor that are blown, most leaking. And also sure enough, I cannot read a value on any of the caps (the ones that are blown). They all look the same. There is a number stamped on top of them "5D 680 J4" it looks like, but that doesn't sound like a cap value. I'd like to recap this board (i used to do Electronic repair work years ago) but I don't know what the value of the caps are. Anyone? I'm new here. Thanks
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Gateway GT5240E recap
    https://www.badcaps.net/store/produc...products_id=79
    • cmlewis89
      LG 47LB5DF blown power supply board
      by cmlewis89
      Hi folks,
      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
      09-03-2024, 07:50 PM
    • drscoot
      HP X360 convertible battery blown fuse error, not charging
      by drscoot
      HP Modelnumber: 14-dh0061nb​
      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
      All these 3 batteries are charging...
      12-15-2023, 05:54 AM
    • swerg
      Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
      by swerg
      Hey everyone,
      I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
      I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
      I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
      06-06-2024, 03:39 PM
    • ohren
      What problems could this blown cap cause in a Marantz SR5400?
      by ohren
      I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
      R533 right below it in the photo is charred, but measures the correct value.
      1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
      10-21-2025, 09:02 AM
    • MrzPdlch
      Blown fuses on Gigabyte GTX 980TI 6GB
      by MrzPdlch
      Hey everyone,
      I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
      Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
      Find some pictures of the actual GPU together with a picture of how it should look like.
      I also wonder whther it might be a problem that there...
      03-10-2024, 04:14 PM
