Win 10 Lenovo M91 Strange issue help.
  • ivtec
    • Dec 2008
    • 1967
    Hi i have my desktop Lenovo thinkcentre M91 and that boots and stays like this;see video ;https://www.youtube.com/watch?v=frZ7L99AFIg
    but i get another hard drive from my other same module and i swap it and it boots and works perfectly. and the HDD that does that issue that is in the video works perfectly on the other Same module computer.
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • Luke Anders
    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
    by Luke Anders
    A few details about the laptop itself:
    Name: Lenovo Legion 5
    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
    BIOS Version: GKCN60WW
    EC Version: GKEC65WW
    Serial Number: PF39AQ7Z
    Board Model: NM-D562 Rev 3.0
    RAM: 16GB Installed, DDR4 (brand new)
    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
    I bought this laptop recently from eBay as a faulty device....
    10-12-2024, 05:13 AM
  • yaya3gmax
    Laptop Power Issue – Works on Battery, Fails on Adapter Load
    by yaya3gmax
    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
    Symptoms:
    • Laptop works normally on a pre-charged battery.
    • Battery does not charge when adapter is connected.
    • Without battery:
      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
      • Speakers “pop” when power cut occurs indicating harsh sutdown.
      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
    08-21-2025, 07:16 AM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • YOUCEF4787
    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
    by YOUCEF4787
    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
    Initial Problem:
    The laptop was completely dead, no signs of life, no power LED.
    Action Taken:
    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
    Current Situation & The Main Issue:
    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
    09-21-2025, 12:19 PM
