Lenovo c460 AIO boot problem
  • fenix1884
    • Jan 2022
    • 6
    • Croatia
    Hi, i have a Lenovo AIO c460 with i7-4790T and 8Gb DDRL memory. It can boot but when a restart it stuck on black screen and i have only led on Power button.
    I tried to flash newest bios but it's the same. Thanks
  • fenix1884
    • Jan 2022
    • 6
    • Croatia
    Re: Lenovo c460 AIO boot problem
    Anyone??
    • ravi_1617
      Lenovo B540 ,Starting Problem
      by ravi_1617
      Hello !
      Model Lenovo B540
      Board Details 09244-1
      LA14 DIS MB
      48.4DMO4.01.1
      This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
      when connected CMOS dont start.
      3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
      One more thing i want to mention ( by mistake i started at...
      10-14-2025, 02:08 AM
    • sopik78
      Lenovo Legion 5 15ACH6H boot problem
      by sopik78
      Hi friends,
      I have a big problem with Lenovo Legion 5 15ach6h, MB Hy660 (661 ...) NM-D562 Rev 2.0.
      Originally, the defective EDP cable found, also a defective LCD panel. After the replacement, the image goes to the BIOS, but it is not possible to boot the system, or install the system, always falls, or restarts directly. Occasionally different BSOD (attached in the attachment).
      So far tested:
      - RAM exchange
      - disconnecting all peripherals
      - Disconnect the battery
      - I have another with a different defect, so the swap of KBC
      - Another nvme...
      12-29-2022, 09:07 AM
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
    • s_specialist
      Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
      by s_specialist
      Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
      07-07-2025, 11:47 AM
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
