GeForce RTX4090 OC24G
    • Jul 2011
    • 6070
    My son is trying to play Call of Duty and the max Frame Per second is 30 or lower depending on what screen he is on
    However the GPU clock speed is reporting “0”
    The GPU vcore voltage values are not stable anywhere from 0.9 to 1.2
    This is with his new graphics card
    Anyone have any ideas of what is going on or what might be the issue and maybe help resolve this issue
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: GeForce RTX4090 OC24G
    30 is fairly low for that card. did u check video settings especially refresh rate of screen
      • Jul 2011
      • 6070
      It turns out that on this motherboard has more than one PCI slot and of course the video card plug in one of the PCI slots ( that was apparently not the right slot for this video card) and when it was moved to the second slot what a drastic difference in performance
      I remembered that back in the day when PCI device slot first became available on motherboard that there were different types so I told my son to plug it in one of the other slots and see for shits and giggles if this makes a difference or not well sure enough it makes a big difference
      We tried 3D benchmarks testing software and on that test it was only 4 frames per second in the first PCI slot with it in the second slot it was 60 something frames per second what a difference in performance same exact test GPU test
      The first PCI slot is a white slot connector and the second and third slots are black this is also what made me think that there might be a difference in what type of PCI slot it was
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        first slot is x16 and other x16/x8. but with that performance it must be x1 or x4. check cpu-z to see how many lines it connected
          • Jul 2011
          • 6070
          With the video card in the best PCI slot deterred by 3D benchmark testing now it around 90 something frames per second
          Now playing Call of Duty the frames per second is now around 140 something very big difference compared to what it was
            NVIDIA GeForce RTX 4090 (RTX4090) Schematic & Board View
            The GeForce RTX 4090 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD102 graphics processor, in its AD102-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4090. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD102 graphics processor is a large chip with a die area of 609 mm²...
            10-02-2024, 08:58 AM
            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
            10-02-2024, 08:52 AM
            NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
            The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
            10-02-2024, 07:51 AM
            NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
            The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
            10-01-2024, 01:54 PM
          • totoagung2
            by totoagung2
            Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
            Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
            01-01-2024, 02:43 PM
