NVIDIA GeForce RTX 4090 (RTX4090) Schematic & Board View
    • 115474
    The GeForce RTX 4090 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD102 graphics processor, in its AD102-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4090. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD102 graphics processor is a large chip with a die area of 609 mm² and 76,300 million transistors. Unlike the fully unlocked TITAN Ada, which uses the same GPU but has all 18432 shaders enabled, NVIDIA has disabled some shading units on the GeForce RTX 4090 to reach the product's target shader count. It features 16384 shading units, 512 texture mapping units, and 176 ROPs. Also included are 512 tensor cores which help improve the speed of machine learning applications. The card also has 128 raytracing acceleration cores. NVIDIA has paired 24 GB GDDR6X memory with the GeForce RTX 4090, which are connected using a 384-bit memory interface. The GPU is operating at a frequency of 2235 MHz, which can be boosted up to 2520 MHz, memory is running at 1313 MHz (21 Gbps effective).
    Being a triple-slot card, the NVIDIA GeForce RTX 4090 draws power from 1x 16-pin power connector, with power draw rated at 450 W maximum. Display outputs include: 1x HDMI 2.1, 3x DisplayPort 1.4a. GeForce RTX 4090 is connected to the rest of the system using a PCI-Express 4.0 x16 interface. The card's dimensions are 304 mm x 137 mm x 61 mm, and it features a triple-slot cooling solution.
    RTX4090​
  • Lvlan Hong
    • Jan 2025
    Thank you!
    • AndreOne
      • Jan 2025
      • Italia
      What application can I use to open the RTX 4090 CAD files attached?
      Thank you​
        • 22135
        Thank you​
        OpenBoardview, FlexBV Free , Boardviewer . https://openboardview.org/
        • kiemmaff
          • Mar 2023
          • America
          Thank you! :3
          • daie3
            • Jun 2021
            • Belgium
            Thank you very much
            • Saiyaman45
              • Mar 2024
              • 8
              Hey Dude, thank you for your contribution, you Rock!!!
              • alas3376
                • Nov 2011
                • 382
                • BENIN
                thank you
                • McWhitePink
                  • Apr 2023
                  • 103
                  hey there, do you have Zotac 4090? the board 1.8V is somehow different from other board. but I couldn't figure out how.
                  if you have Zotac 4090 boardview, I would be grateful
                  • karsonluv
                    • Mar 2025
                    Thank you so much for the 4090 strix board view!! I have a dead short on PL4 and PML2. Any direction to track down the source of the short would be helpful. I have an injector and thermal cam. The card in question is a TUF but seems to be just about the same board config as the strix.
                  • Wenwen Ha
                    • Mar 2025
                    • 中国
                    thanks
                    • Sofian75
                      • Aug 2023
                      • 87
                      • France
                      msi rtx 4090 gaming x trio
                      • Drex00
                        • Jul 2025
                        • Brazil
                        do you guys have palit / gainward rtx 4090 bv ?
                        • tanneride
                          Pro Meddler
                          • Jan 2025
                          • 9
                          Sorry to bug you, but i get an 'Invalid File Specified' when trying to download this. Thank you for uploading if you can re-up?
                          • Sofian75
                            • Aug 2023
                            • 87
                            • France
                            Here
                            • tanneride
                              Pro Meddler
                              • Jan 2025
                              • 9
                              Here
                              Thank you! working on a 3090ti x trio right now and its nearly an identical board (MS-V509) - this is very helpful
