Dead ASUS ROG STRIX X299-E Gaming Motherboard
  • SavaBogdan
    • Nov 2021
    • 9
    • Romania
    Hello. I am having some trouble with a X299 motherboard. I did some searches and I found very little info about these X299 chipset motherboards. It's a bit strange because they are known to be unreliable and I expected to find lots of posts. So I decided to make a thread and ask the experts for help
    Ok, here is the info I have.
    The board is completely dead, nothing happens when I try to start it up.
    I stripped it down and started measuring. I have 3.3v on the power on switch pin, so that is ok. I also found 1v on a coil near the sata ports and 3.3v on the coil next to the battery. These are all standby voltages.
    I am attaching a picture with the board and the voltages.
    The first problem I found is 0.3v on the vbat pin on the SIO. I checked the battery and it is ok. I also removed the battery and measured the voltage on the + tab on the socket. I also have only 0.3V there with the 24pin power plug on.
    From what I read the battery is supposed to power the ICH chip, so could that be faulty? It's not that easy to reball and solder it back on (I don't have a stencil for it and manually placing balls is not fun) so I would like to be as sure as possible before I go and desolder it.
    I have a pdf schematic file for an ASUS x299 board that is very similar to mine but I can't manage to find "bat" on it. I do get 28 instances but I can't see them, and adobe and chrome crashed several times while trying to scroll the file. It has too many elements I think and it just freezes. How do you guys use these pdf files?
  • SavaBogdan
    • Nov 2021
    • 9
    • Romania
    Re: Dead ASUS ROG STRIX X299-E Gaming Motherboard
    Ok, so after a bit more measuring and trying to see where else could the 3.3v from battery could be shorted, the voltage began to drop even more. I took out the thermal camera and started to look around the board. I noticed the chipset had like an aura around the die, very faint but it was warmer.
    So I unplugged the board, I put a heatsink on the ICH to cool it down as best as I could, plugged it back in and then measured the voltage again. Now it was 0.5v.
    I removed the heatsink and started heating the ICH and voltage qiuckly went down below 0.3v again.
    So, being pretty sure that the ICH had a short on the 3.3v from battery I took it off. And behold, now I have 3.3v on the battery + tab and on the SIO chip.
    In hindsight I could have identified the resistor that passes the 3.3v from the battery underneath the chip and apply 3.3v there directly. The chip should have heated up pretty quick.
    So guess I was right to suspect the ICH New one is ordered and I will post here after I install it and hopefully have a working motherboard.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      I'm shocked that they seem to be known for being unreliable!
      That's something I would expect on a cheapo socket AM4 motherboard, FFS!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • SavaBogdan
        • Nov 2021
        • 9
        • Romania
        I mean, that is my opinion based on several friends that had repeated X299 motherboard failures and the amount of bad X299 and older X99 boards I came across on a local site similar to ebay. Like I said, I couldn't find much information on specialty forums so I may be wrong
        • anikin73
          • Mar 2022
          • 112
          • singapore
          Let me help u out a bit here. Since u are sure that u have vbat at SIO to be 0.3v.
          I am amazed u took out the pch by so little info
          • SavaBogdan
            • Nov 2021
            • 9
            • Romania
            Well, what other options were there? The 0.3v were also on the battery tab, so that would indicate a short on a component that was powered by the battery. The PCH is powered directly by the battery. I tried to trace the path from the battery to the PCH using a boardview from another x299 board and a PDF schematic of a ASUS x299 board. All the components were ok. I even desoldered a few resistors that seemed suspicious but when out of circuit they measured ok. And in the end when I saw that the voltage at the battery tab changed with the temperature of the PCH (resistance changes with temperature) I was pretty sure that was the problem. So I took it out and it seems I was right
            • stormanimal83
              • May 2014
              • 74
              ... by the way. that doesn´t have to mean that pch is bad. could be the solder balls under it... but its not worth the risk for reballing... are u sure the vbat line starts from there? normally its not the case... it´s connected to a shottky diode at first...
                ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                09-07-2024, 01:00 AM
                ASUS ROG STRIX-G16-G614JV-N4008W Notebook Strix G16 Specification for Upgrade or Repair
                This specification for the ASUS ROG STRIX-G16-G614JV-N4008W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the STRIX-G16-G614JV-N4008W boardview and STRIX-G16-G614JV-N4008W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-07-2024, 06:40 AM
                ASUS ROG STRIX-G17-G713PI-LL044W Notebook Strix G17 Specification for Upgrade or Repair
                This specification for the ASUS ROG STRIX-G17-G713PI-LL044W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the STRIX-G17-G713PI-LL044W boardview and STRIX-G17-G713PI-LL044W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-07-2024, 06:38 AM
                ASUS ROG Strix Notebook Strix SCAR 15 Specification for Upgrade or Repair
                This specification for the ASUS ROG Strix Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Strix boardview and Strix schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ROG Strix Notebook...
                09-07-2024, 06:21 AM
                ASUS ROG ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB Notebook Strix Specification for Upgrade or Repair
                This specification for the ASUS ROG ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB boardview and ROG Strix G15 15.6" i5-10300H 8GB 512GB GTX 1650Ti 4GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                09-06-2024, 11:20 PM
