Must this Nuvoton NCT6797D-M Super I/O IC be programmed?
  • ihatepwm
    • Mar 2023
    • 5
    • England
    Hello there;
    I have a MSI x570 Tomahawk board. SuperIO chip seems to be faulty. SuperIO chip on this spesific board is NCT6797D-M. I've ordered new one. Does it need to be programmed?
    Here the datasheet: https://cdn.badcaps-static.com/pdfs/...3f507a863c.pdf
    Thanks!
  • DynaxSC
    • Apr 2021
    • 470
    • Poland
    Re: Must this Nuvoton NCT6797D-M Super I/O IC be programmed?
    Hi, usually SIO's do not be programmed and can be exchanged w/o any additional measures. However sometimes they have an separate small capacity kind bios chip connected, and these must be working and programmed. The question is how you determined that they SIO is faulty ? Except its very hot, usually other reasons are responsible for motherboard not starting, and it's only looking like SIO is not working. Eg. it's more likely that some components are missing on the motherboard, or VRM chips are faulty.
    • ihatepwm
      • Mar 2023
      • 5
      • England
      Thank you for your reply. It seems like I've crushed SIO's pins while connecting a GPU and bridged them (probably shorting them after I turn my PC on). It was not booting at all before, but after playing around, it started booting with a weird flaw.
      My PC works normally (I can play games, do work, do benchmarks, and even write this post), but I can't turn it off. When I shut it down from Windows, BIOS, Linux, or even with a long press of the power button, it turns off but restarts again with "CPU Error Led" and the fans spin at full speed until I unplug it from the wall. After waiting a few minutes, I can turn it on again normally.
      I've tried it with different RAMs, CPUs, PSUs, and GPUs. Ive reseted BIOS, downgraded it. I had my motherboard professionally cleaned and the SuperIO chip re-soldered. After a visual inspection and checking for missing components (from the pictures online), I decided it should be either SuperIO or Chipset. After checking functions of SIO and since SIO is cheap, I thought I should give it a try.
      • nemo123
        • Jul 2024
        • Czechy
        Did replacing the Nuvoton chip worked?
