D5400XS cap replacement
    While working on my D5400XS motherboard, I knocked off one of the caps by the northbridge. The markings say "721 SEPC 560 2.5" and it is purple. Can someone help me identify this capacitor and where to buy a replacement? The legs got ripped out. Images:
    http://img688.*************/img688/7686/0904101410a.jpg
    http://img13.*************/img13/7008/0904101428a.jpg
    Thanks in advance!
    Re: D5400XS cap replacement
    Sanyo OS-CON SEPC Series 560uF 2.5v
    Mann-Made Global Warming.
    - Dr Seuss
      I cant seem to find the 2.5v version anywhere, would it be ok to use the 4v one?
        The voltage marked on a cap is it's limit so one with a higher limit is fine.
        Make sure the diameter works.
        Different diameters have different lead spacings.
        - Dr Seuss
          Ok i found one that is very similar in specs but the ESR is slightly different as well as the ripple current rating. Would this work?
          http://search.digikey.com/scripts/Dk...me=493-3004-ND
          Or would i be better off with this one?
          https://www.badcaps.net/store/produc...e0c165f16636bf
            The one at digikey has slightly better specs than the original OS-CON SEPC.
            I dunno specifically what BCN has since the series and ESR isn't mentioned.
            - Dr Seuss
