HP ProDesk 600 G6 SSF, 6 long, 3 short beeps
  • DianneW
    • Feb 2022
    • 19
    • South Africa
    Does anyone know what the 6 long, 3 short beep error code points to on an HP 600 G6 SFF ?
  • NanoPat
    • Jan 2023
    • 11
    Re: HP ProDesk 600 G6 SSF, 6 long, 3 short beeps
    Hi.
    Cannot find that beepcode listet for troubleshooting on HP website too. Is there a previous story like changed components, was it transportet, bios update attempt etc.? If not happened allready u should try the basic steps.
    Unplug PSU, remove CMOS battery, check all components especiall RAM and Graphiccard for proper seating, use only one RAM modul on different DIMMs and unplug all unnecessary peripherals etc.
    Is there any changes?
      • 22135
      Are you sure it isn`t 3 long ,6 short ?
      Maintenance and Service Guide - https://cdn.badcaps-static.com/pdfs/...2d9c4bc44f.pdf
      HP ProDesk 600 G6 Small Form Factor PC - Part Locator - https://cdn.badcaps-static.com/pdfs/...97a1915e9b.pdf
      HP ProDesk 600 G6 Small Form Factor PC - LED Simulator - https://cdn.badcaps-static.com/pdfs/...a99bb6fe48.pdf
      • DianneW
        • Feb 2022
        • 19
        • South Africa
        Originally posted by NanoPat
        Hi.
        It's a brand machine, and I've done all the basic troubleshooting, removed cmos battery and storage devices, swapped the PSU, RAM and Processor for known good ones, and the machine is using onboard graphics. I suspect the PCH is faulty.
        • DianneW
          • Feb 2022
          • 19
          • South Africa
          It's definitly 6 long and 3 short, not the other way around. Other HP manuals say the code is for a "serious motherboard component failure". I suspect its the PCH, its getting fairly hot when injecting voltage onto the 3.3volt rail.
