ROG Front Base repair
  • paparazzo79
    • Dec 2018
    • 299
    • Bosnia
    Hi guys.
    I ordered used ROG front base guy claiming it is working.
    But when I got home,I installed it with my MoBo which is supported and only got white backlight..
    It was a rip off,luckly did not paid much for this thing.
    But carefullly inspecting the board I see broken notch on SATA connector so my assumption is that maybe someone was installing the SATA power cable from PSU in opposite direction and fried "something" on board (look at the pic below).
    So with your guys experience what do you think, if that is the case, what component(s) could be dead, and what to test and how in order to try to repair this thing?
    Luckly I ordered second one, this time from other guy claiming this one is working.
    So maybe I will have 2 of them and judging by the working one maybe I could test the working one and compare voltages,ohms,amps or diode mode with failed one.
    But I dunno which components should I test first for failure?
    I did some pics so you guys can see the PCB.
  • captainKKK
    • Sep 2018
    • 287
    Re: ROG Front Base repair
    I wish I had something that took those kind of pictures. What is it? Otherwise I have no clue what kind of thing you are talking about and probably nobody else can troubleshoot your issue until you post so MODEL NAMES AND NUMBERS for the thing in your pictures. Assuming that little lack dot it the controller, and then you should check the ribbon cables for damage. Assume that your MB plugs into that broken female socket, the socket is not the issue unless the contacts are damaged inside. It looks like to me the CONTACTS for that connector are on the side closest to the physical board, have you looked at them?..there should be 15 visible contact stripes inside that female scoket. If the contacts are carbon and on the top of the socket, the one on the RIGHT is damaged. You could always HOT GLUE your connector if it is. Give us som more pics from way further back and some model number and manufacturer.
    • paparazzo79
      • Dec 2018
      • 299
      • Bosnia
      The device name is Asus Rog Front Base.
      I took pics with Samsung Galaxy Note 10+
      • DynaxSC
        • Apr 2021
        • 462
        • Poland
        Download the user manual to this "invention", you need some "ROG_EXT Cable" as well as an AAFP audio cable for it to connect to mobo. Do you have it ?
        • paparazzo79
          • Dec 2018
          • 299
          • Bosnia
          The working one came 2 days ago and works normally.
          So now I have 2 working and none working one.
          What now?
          • paparazzo79
            • Dec 2018
            • 299
            • Bosnia
            I'd probably need microscope to check those contacts and I am not pro not either amateur in repairing this stuff.
            • paparazzo79
              • Dec 2018
              • 299
              • Bosnia
              So assuming he did plug sata power cable opposite way to tje board what potentially could be damaged?
              I see a lot of caps near connector one chip and one mosfet/transistor.
              • paparazzo79
                • Dec 2018
                • 299
                • Bosnia
                I connected it once again to MoBo and I am geting only backlight.
                So I assume this repair is not for amateurs
                Probably smth messed up with power circutry.
                • astroboypaul
                  Surface Book 2 Performance Base dead
                  by astroboypaul
                  I'm working on a Surface Book 2 performance base (M1032224-004 on white sticker) and would love for some help troubleshooting or where to look next.
                  The tablet when not connected to the base seems to work fine, but:
                  • When tablet is off and connected to the base, it won't turn on.
                  • Connecting tablet that is already on to base there is a windows device detected tone (not sure what device), but tablet remains in tablet mode, keyboard/trackpad don't work, and windows continues to report only 1 battery.
                  • Charger white light turns on when connected to the base, but base battery and tablet
                  04-25-2025, 12:40 AM
                • survivalbloke
                  Am I using my microscope wrong?
                  by survivalbloke
                  I've got a nice microscope to use, but I'm sort of a noob with microsoldering. I've gotten MUCH better over the last 6 months(with the help of this forum) but one thing is that I have sometimes struggled to get the scope high enough. You'll see in this image that I have the arm at its highest position possible, and I've also got the entire thing sitting on an old laptop for an extra couple inches.
                  So, there's that, which I just talked about, as well as the fact I hate the bulky base of this thing. I'd love to take it off the base and bolt it directly to my work surface. Maybe even...
                  09-07-2023, 01:07 PM
                  HP ProBook 650 G4 + Samsonite Base Boost Notebook 600 Specification for Upgrade or Repair
                  This specification for the HP ProBook 650 G4 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G4 + Samsonite Base Boost boardview and 650 G4 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  09-06-2024, 09:00 AM
                  HP EliteBook 830 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 830 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Samsonite Base Boost boardview and 830 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                  HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
                  This specification for the HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Samsonite Base Boost boardview and 1030 G3 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
