The green light on the PS is on when plugged in and the orange light on the motherboard is lit but there is no response of any sort when I press the power button on the front. The led on the power button does not light and there is no beeping. What I have tried is shorting the PSU with a paper clip from the green wire to the adjacent black wire in the 24 pin plug and the PSU fan turns on and the CPU fan starts at max speed. With the CPU fan still at high speed, I remove the CPU four pin power connector (12v black and brown wires), from the motherboard and when I am testing the voltage diagonally with my VOM meter, it indicates 0.6v, the system starts and boots into windows, AFTER I plug the 4 pin CPU back into the motherboard and remove the PSU jumper. Memory is good, and no periferals are plugged onto the MB. BIOS battery was replaced and erased using the jumpers. I replaced the obvious bad caps on the PS to get to this place as described above. Any ideas?
Inspiron 530S - boot issue
Tags: None
Re: Inspiron 530S - boot issue
Mark this one as a tribute to Badcaps forums as fixed. After tear down the PS the second time , I found a 2200uf 10v cap hiding deep inside, that was just barely pouching at the top and after replacing this 10 cent cap, it has worked perfectly for 10 reboots and 8 hours of operation. Never think that ONE bad cap will not fix your issues.
by abajorI have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
Right now I'm trying to dig through the PDF schematics and Board... -
by SafioHello
My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
thank you
06-08-2024, 08:43 PM -
by danielsakHello, I have issue with Dell Inspiron 3542.
Motherboard marking:
Code:Cedar_Intel-MB 13269-1 PWB FX3MC REV: A00
- The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
- The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
Thanks in advance! -
by lukkihapsiAsus Vivobook X515JA Laptop
Issue :
Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
Tried :
Cleaned inside for dust, applied fresh thermal paste. No Change!
Removed keyboard, Trackpad, fingerprint sensor. No Change!
Removed Internal SSD. No Change!
Updated BIOS to latest version. No Change!
Removed battery and pressing power button for 1 minute. No Change!
Weird Part :
Upon turning laptop ON, screen lights up - stays black,
I... - Loading...
