ASUS RT-AX88U router DEAD
  • josweet
    • Nov 2015
    • 17
    Hi Can anyone help identify this component pls
    The Asus RT-AX88U router is dead & fault finding brings it to a DC to DC convertor. 3.3v goes in, but nothing comes out. The IC is marked "3002 0ST1"
    There is a 2nd working small IC marked "3001 0gt1" that converts 3.3v to 1.8v, both power separate CPu's on the board.
    I have also searched for a schematic for it, to no avail.
  • CapLeaker
    Leaking Member
    • 7978
    Re: ASUS RT-AX88U router DEAD
    Check the if the output is shorted to gnd via the caps too.
    • waveslinger
      • Dec 2022
      I have the same model router with exactly the same fault, please let me know if you manage to fix it or find any info on the dc-dc chip, coil or caps.
      It's a pain to work on, requiring lots of back heat to remove the SMD components, mine has about 92ohms to ground on the output of that circuit.
      Martin
      • mikochem
        • Dec 2022
        • 6
        • France
        I'm trying to repair the same model but in my case it appears to be a different fault...
        https://www.badcaps.net/forum/showthread.php?t=113203
        Would someone with the same router be so kind as to help me identifying U613 ? I'd like to confirm whether U613 is the same as U614 on the PCB or not.
        If I can resurrect that thing I'll definitely keep you posted.
        Cheers,
        Michael
        • waveslinger
          • Dec 2022
          Hi Michael,
          On my board, U613 and U614 are both 0Q=13V
          Thanks,
          Martin
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            It might not be the same case as yours , but still , it occurred many times with me lately . The adapters , although measuring the right voltages , depending on models , but it seems at load they were failing , in amperage of course . On trying another ones , routers would work smoothly .
            • mikochem
              • Dec 2022
              • 6
              • France
              Originally posted by waveslinger
              Hi Michael,
              Thanks,
              Martin
              Thanks a lot Martin !
              • matusalens
                • Mar 2023
                • Brasil
                Hi I have one RT-AX88U Dead, but in my case is caps of L1126 area, after remove 5 caps and test with energy power, my router come back to life.
                Someone can please tell me caps specs??
                • Lasermi
                  • Sep 2023
                  • EspaΓ±a
                  Hi there to all,
                  In my case, a cap on the L1126 area was clearly cracked. Router was dead, apparently the power supply was shorted. I removed it and router came back to life. Unfortunately I don't have the specs but I'm planning to replace it with a 4.7uF 50V 1206 X7R. Since I could see many other caps in parallel and the router already works without it, I can only guess it's not that critical. I will post my results.
                  • RedDragon9
                    • Oct 2023
                    I also have a ax88u with no power. I'm getting 19v coming in but seems like the DC convertors are no being enable as I get no output. I am getting a half volts on the LEDs and 1V on U24. Any help please
                    • poster1
                      • Nov 2022
                      • 19
                      • Poland
                      My ax88u has U24 chip burned. 8 pin SMD, markings are unreadeble. Can any1 help me indentify this chip? Or post a good quality photo of it?
                      • Yang Sail
                        • Apr 2025
                        • China
                        My AX88U also failed, and I see that the model number for the U24 is 1L=12T for your reference.
                        I would also like to ask how many volts is the output of the IT76630M chip at U3 (I have a faulty R1 resistor) and I need to determine the value of the R1 resistor.
