Nec pf5240 factory reset
  • pirusvlad
    • Apr 2021
    • 13
    • uk
    need help factory resetting this switch, been searching for weeks but found nothing
    sorry for opening a new thread but didn't find anything like
  • masterm
    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
    by masterm
    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
    Problem with TV:
    - Netflix stopped working so i tried to do factory reset from the TV menu.
    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
    - After waiting for some time, the TV went into a boot loop.
    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
    04-30-2024, 03:03 AM
  • mon2
    Hisense 55Q9G Android reset / factory firmware reload
    by mon2
    Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
    After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
    01-03-2024, 10:25 AM
  • pfrcom
    Reset/erase Hynix SC210 to factory default
    by pfrcom
    Some Googling made this seem straightforward, but it ain't necessarily so:
    First try was Hynix Drive Manager, supposed to be able to do PSID reset
    In Win7 x86 context, what shoddy software – this greeted me first time I clicked it from Start menu:
    After wild goose chase triggered by the OpenGL bit, I tried swapping graphics cards until penny dropped when it still objected to a Radeon HD3450
    How I got it work:
    1. Command prompt
    2. Change to install directory \Program Files\SK Hynix Drive Manager
    3....
    04-23-2022, 07:30 AM
  • LEONARDO DE FREITAS
    Chinese multimedia crashes on the home screen, could someone help with the software or factory reset?
    by LEONARDO DE FREITAS
    Hello everyone, I have 2 multimedia systems with a 9-inch screen that turns on and only stays on the Android screen. It is very likely a software update. I have 2 software programs here but the multimedia system does not start the installation. Has anyone encountered this problem? I would be grateful if you could help.
    04-18-2025, 09:58 AM
  • AJ847.63e
    A1708 unable to reinstall Monterey after factory reset - disk utility error 478
    by AJ847.63e
    I've got a A1708 which we decided to sell off as we no longer use it. We factory reset the device to wipe all data which went fine but when trying to reinstall macOS it fails with the generic “ MacOS “Installation Failed, An Error Occurred While Installing”. I've tried the usual solutions like the first aid utility apple recommends and also disc utility delete the partitions but still get the same error. Digging into the logs you can see it's giving an error 478 but unfortunately wasn't able to get much info on that on google so I'm unsure where to go from here....
    02-20-2023, 02:51 AM
