IP address conflicts after waking up from standby/hibernation
  • japlytic
    • Oct 2005
    • 2086
    On rare occasions, I get an IP address conflict after waking up from standby or hibernation.
    On our network with three computers (set to DHCP), we have a printer at 192.168.1.20 (static) and an ADSL/wireless router at 192.168.1.254 and the DHCP server starts from 192.168.1.1
    It is highly unlikely that there is a conflict with the printer.
    To say simply (taking note that both PCs are set to DHCP), PC "A" has an IP address of 192.168.1.2 and PC "B" is off. PC "A" hibernates and PC "B" is turned on and receives an IP address of 192.168.1.2.
    When PC "B" still has this IP address, PC "A" resumes from hibernation and tries to use IP address 192.168.1.2 , resulting in an IP address conflict.
    Why can't network clients configured for DHCP renew its IP address after standby or hibernation (even though some renew the IP address when there is a conflict)?
    • 31017
    Re: IP address conflicts after waking up from standby/hibernation
    use fixed i.p.'s
    standby will lose the dhcp table,
    suspend will make the other machine delete the dhcp entry after a timeout period.
    or:
    run a nameserver and assign a fixed i.p. to each domain-name.
    then when you start the pc it will always be assigned the same i.p.
    • kikkoman
      • Jul 2007
      • 691
      or check if your router can be set to always use the same adress for each device.
      some can, some not.
      my Thomson router does it via binding the IPs to the MACs (and can be set individually for each client).
      it's a bit less trouble than the all-static way since you don't have to configure the DNS settings client-side.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • seanc
        • Nov 2008
        • 1319
        Agreed, set your router to always give the same IP address to a particular device/MAC address.
        If your router doesn't support that, turn it's DHCP server off, build a Smoothwall. Enjoy.
        • retiredcaps
          • Apr 2010
          • 9271
          On some home based routers, you can set the DHCP lease time to 1 hour through 1 week. If you set it for a "longer" period, this *should* force the router to keep the MAC to IP binding even if the end device is asleep or hibernating. It *should* also prevent the router from handing out that used IP address because the MAC to IP binding still exists.
          --- begin sig file ---
          --- end sig file ---
          • AudioCraZ
            • Sep 2009
            • 147
            There is an easier way to fix this.
            In most routers, you can set the IP address via MAC address of a computer. That way, on some rare chance that something else gets on your network, it won't get your ip address because the router (DHCP server) is assigning the IP's, and it knows not to give away the IP set for your computer.
            • NxB
              • Feb 2009
              • 1595
              Just extend lease time. That is the easiest way.
              • mattch
                • Mar 2010
                • 121
                aggreed.
                static ips for the home computers with exception of wireless client is way to go. so much easier and after a while you begin to correspond computers to IP internally without netbios or dns so your not always second guessing or having to do that extra step.
                i got a low memory and dont use page files so that extra step would irritate or possibly mess me up when im in the zone doing a project. LOL
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • bobale
                  Samsung S2230N not waking up from standby
                  by bobale
                  Hello guys, I have this Samsung S2230N LCD monitor which is not waking up from standby, I've checked a lot of things, but came up short.
                  So, when you plug the monitor in AC outlet, it starts up and then immediately goes to standby, as if computer is connected, but it is switched off (the computer, that is). Of course, VGA cable is not connected, and there should be Check cable, No signal, or something similar on the screen, but there isn't. When you press MENU button, the panel does turn on, it shows Test Good, in the upper left of the sceen, and then goes off. As I understood, this...
                  12-25-2020, 10:43 AM
                • fharris1977
                  Vizio D50u-D1 Dead Set No Standby
                  by fharris1977
                  Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                  12-28-2023, 10:25 AM
                • Crystaleyes
                  Samsung BN44-00259A standby question
                  by Crystaleyes
                  Hi all.
                  I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                  SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                  Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                  The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                  08-11-2023, 05:15 AM
                • psssst
                  Yamaha TSX 120 Standby Problem
                  by psssst
                  Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                  03-01-2024, 07:25 AM
