Technicolor TG789vac v2
  • ERS
    • Sep 2017
    • 7
    • Portugal
    Does anyone have any schematics from this equipment? Component datasheets, anything!
    Thanks!
    • 31121
    Re: Technicolor TG789vac v2
    is it a router?
    • ERS
      • Sep 2017
      • 7
      • Portugal
      Originally posted by stj
      is it a router?
      Yes!
        • 31121
        cant find any info yet - technicolour are usually isp supplied junk that has other names on the outside though.
        whats wrong with it?
        • ERS
          • Sep 2017
          • 7
          • Portugal
          Actually it is not one unit, most likely, I will receive a batch of equipments to be rapaired and at this point I am researching the most common faulty components.
          I already analized and found some, fixed with components from donor equipments that were tested OK, but the main problem here is that there are quite components that I cant find datasheets.
          Thanks!
            • 31121
            main parts that fail in routers, electrolytic caps,
            and eventually wifi chipsets.
            if they have been in a storm then sometimes a transformer or network chip or related ceramic caps
            unless they are very high spec - like VDSL2 with atleast 5 gigabit ethernet ports, they arent worth touching.
            you can get 5 port VDSL2 routers that are OpenWRT compatable and still new in the box on ebay for about €15
            i have a couple.
            • ERS
              • Sep 2017
              • 7
              • Portugal
              When it comes to Lan controller, Wifi controller and CPU, forget about it, BGA with profile needed! Not worth it!
              Yes, most fixable parts are LAN port, all ports 1gigabit, dc plug, power button and some smd caps in short circuit.
              The second picture, the power circuit, I think it is most likely a transistor, and in the first picture, it's the phone circuit, I think those components are some dc converters.
              Anyway, both cases I can't get any datasheets
              Any opinion is welcome!
              Last edited by ERS; 10-02-2021, 05:16 PM. Reason: wrong order of text relating to attachments
                • 31121
                what's printed on the part?
                  • 31121
                  so i found these:
                  https://openwrt.org/inbox/toh/technicolor/tg789vac_v2
                  https://www.choice.com.au/products/e...89vac-v2-iinet
                  read the comments section of the second link.
                  these things have a lot of issues!!
                  • double_DD
                    Why does my ISP router hate my "homemade" power supply??
                    by double_DD
                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                    07-12-2025, 03:09 AM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                  • shadow666
                    Router Xiaomi M4A Gigabit
                    by shadow666
                    hello
                    i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                    Mi Router 4A Gigabit Edition
                    ROM CHIP is 16 MB
                    i attached picture of motherboard​...
                    11-30-2024, 03:49 PM
                  • EasyGoing1
                    UPNP, "Standards" and hardware that implements it
                    by EasyGoing1
                    I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                    One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                    So I decided to implement UPNP...
                    07-16-2022, 07:12 PM
                  • BOSCHNJAK
                    by BOSCHNJAK
                    ABOUT ME INTRODUCTION FILE
                    2
                    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                    2022 BEV, PROJECT ?
                    2021 BEV, PROJECT ?
                    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                    12-28-2023, 02:09 PM
