Looking for Flash dump from Zyxel devices
  • highland
    • Aug 2020
    • 7
    I'm looking for flash dumps for my following bricked Zyxel devices;
    XMG3927-B50* (also accepted alternatives VMG3927-B50* and VMG8825-B50*)
    and also,
    VMG3925-B10*
    Thanks in advance for all your support.
    • 31778
    Re: Looking for Flash dump from Zyxel devices
    "The Zyxel XMG3927-B Series supports TR-69 that simplifies remote configuration, upgrade and management and therefore improves cost effectiveness and customer satisfaction. Additional support to the latest TR-181 issue-2 data model also enhances service providers’ visibility on subscriber LAN networks"
    backdoor infested junk - what isp supplied that unit??
    • highland
      • Aug 2020
      • 7
      From 'Elisa', FIN.
      It boots but it can't find config file and reboots. That zcfg_config file is missing. Can't update or upgrade via serial connection either. Perhaps, only option is to get a full flash dump and rewrite the nand.
        • 31778
        it probably has a serial port on the board, so you could get in with that.
        but you really need to convert it to openWRT or atleast cross-flash it to whatever the model was that was sold direct to the public without isp specific locks in it.
        • highland
          • Aug 2020
          • 7
          I've serial access to the device. The CFE is locked with new algorithm, which is different to known old algorithm. Thus, I can't enable 'BootExtension Debug Flag' to flash vanilla/generic firmware either. I know, some UK ISPs devices are not CFE locked and can be flashed to get rid of ISP traps.
            • 31778
            is the flash bga or something socketable?
            or is there an identifiable jtag port?
            • highland
              • Aug 2020
              • 7
              It is ESMT F59L2G81A, TSOP48. I've RT809H to flash the nand.
              Not identifiable JTAG port.
                • 31778
                o.k. try to find out what other model numbers are the same pcb.
                is it marked on the pcb?
                • highland
                  • Aug 2020
                  • 7
                  Not much idea about which other models share the same pcb, but I was confirmed that vmg3927-B50* and vmg8825-B50* also share the same bootloader as of xmg3927-B50*.
                    • 24176
                    might help - https://forum.kitz.co.uk/index.php/topic,23648.60.html
                    • highland
                      • Aug 2020
                      • 7
                      Originally posted by SMDFlea
                      Thank you for the link. The device's CFE Bootloader is locked thus I can't enable 'BootExtension Debug Flag' to be able to flash via serial/UART connection either. I need to reflash the NAND with an external programmer to unbrick it. I was hoping to get a complete NAND FLASH DUMP from any device similar or same as KCOM.
                      • lilos
                        • Nov 2025
                        • 16
                        • poland
                        Hi guys
                        I need a working 2MB SPI flash dump for a 2.5G switch Zyxel MG 108 rev B1
                        The original Macronix chip was acting up and data layout in parameter section got corrupted but the chip itself is actually fine because it programs normally now in NeoProgrammer
                        My hardware is 100 percent ok all rails are perfect Core VCC is 1 14V AVDD analog is 0 95V and IO lines are 3 3V LED shift registers show no shorts on megaohms
                        When I flash the original backup onto the chip the CPU boots up and prints this via UART 115200:
                        uart init ---------------- done
                        flash driver init ------- done
                        Right after flash driver init the CPU pulls Pin 1 CS high to 3 3V and halts completely because of a configuration error or checksum block mismatch No LEDs flash on front panel and Windows shows unidentified network
                        Board markings and info:
                        Board PCB: 270 NB1 MS208A004B1 REV B1 (Platform MS208A)
                        CPU: Realtek RTL8373
                        PHY: Realtek RTL8224
                        PN: 951 ZY0 MS208A00B00 / 961 ZYO MS208A00B00
                        SN: S224348002043
                        I tried alternative firmware like RTLPlayground but it crashes immediately at address 0x000000 because of different boot ROM header alignment in this specific Zyxel B1 revision
                        If anyone has a working original bin backup from a working donor board please upload it here
                        I am attaching my original corrupted dump just in case someone can fix the parameter block layout in hex
                        Thanks in advance for any help
                        • lilos
                          • Nov 2025
                          • 16
                          • poland
                          Hi I need also full dump for zyxelxgs1210-12 rev B1 or at least orginal U-boot if anyone can upload would be great.
                          • JayZee
                            Samsung Odyssey G9 C49G95TSSR / BN94-17725A – full SPI flash dump needed (M-T9549GGAA / T9549)
                            by JayZee
                            I am trying to repair a Samsung Odyssey G9 49" monitor and I suspect corrupted firmware / NVM data or a bad SPI flash.
                            Monitor details:
                            Model: Samsung Odyssey G9
                            Model: C49G95TSSR
                            Model code: LC49G95TSSRXEN
                            Type No.: C49G95TSS
                            Version No.: CA02
                            Mainboard: BN94-17725A
                            PCB: BN41-02843B
                            Firmware/platform marking: M-T9549GGAA-1017.0
                            Official Samsung USB update available: M-T9549GGAA-1020.0
                            Scaler/platform: Novatek NT68500 / T9549
                            SPI flash: Winbond 25Q40CLSIP (if it is the right chip)...
                            05-15-2026, 04:16 AM
                          • spmetroil
                            Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                            by spmetroil
                            I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                            The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                            I have a CH341A programmer and I already attempted the following steps:
                            1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                            2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                            3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                            08-19-2025, 09:23 AM
                          • zack189
                            LG 42LD450-TA SPI Flash Dump Request - EAX61352203 - MX25L8006E
                            by zack189
                            I'm hoping someone can help me with an SPI flash dump for my LG 42LD450-TA (Asian/Malaysian market variant).
                            Board details:
                            Model: LG 42LD450-TA
                            Main board: EAX61352203(1)
                            Chassis: LB01B
                            Flash chip: MX25L8006E (1MB)
                            Board sticker: EBR60721201 / TDY1-S001D
                            Symptoms:
                            TV does not boot. Slow-blinking red LED when ON button is pressed on remote or TV. PSU is confirmed working, all voltage rails on main board are present. Reflow attempted with no success. Fault has been diagnosed as firmware corruption.
                            What...
                            03-25-2026, 01:09 AM
                          • sterncan
                            Samsung Odyssey G9 BN94-17725A SPI flash dump needed (T9549 / NT68500)
                            by sterncan
                            I am repairing a Samsung Odyssey G9 monitor.
                            Model: LC49G94TSSRXZG
                            PCB: BN41-02843B
                            Scaler: Novatek NT68500 (T9549 platform)
                            Flash: Winbond W25Q128JVSQ (16MB)
                            Problem:
                            Monitor only shows standby LED.
                            No backlight, no OSD.
                            SPI flash verify is OK.
                            Original dump seems corrupted or boot structure damaged.
                            I am looking for a full 16MB SPI flash dump
                            from a working BN94-17725A board.
                            I can share my original dump if needed.
                            Thank you very m...
                            02-26-2026, 05:32 AM
                          • Robert Zabka
                            OKI MC883 - need SPI flash dump - W25Q512 (25Q512MCFIG) - power outage brick
                            by Robert Zabka
                            Hello, I have an OKI MC883 multifunction printer that was bricked after a power outage. The firmware got corrupted during the outage. Symptoms: - Display shows OKI logo then turns off - Motors run briefly (self test) - Network LED active but no IP assigned - Boot Menu (hold "6" on keypad during power on) not accessible I have identified the SPI flash chip on the main board: - Chip marking: 25Q512MCFIG - Package: SOIC16 (300mil) - Location: IC27 on Board-6CU I have CH341A Pro programmer and SOIC16 clip ready. I just need a clean raw flash dump to restore the firmware. OKI public firmware...
                            06-11-2026, 06:06 AM
