Packet loss on LAN...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Packet loss on LAN...
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      • Bulgaria
      Originally posted by eccerr0r
      True story. Ask me something and I will tell you.
      Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
      1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Originally posted by televizora
        True story. Ask me something and i will tell you something wrong or useless.
        fify
        • televizora
          ghettomodmaster
          • Nov 2016
          • 957
          • Bulgaria
          fify
          Care to share? Or clarify?
          Or you just use ping -f -i -l?
          Because otherwise ping usually waits for the reply before sending another request.
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • davg
            Home network connection problem
            by davg
            I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
            03-06-2021, 07:13 AM
          • japlytic
            Maximum speed should be marked on network ports
            by japlytic
            I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
            One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
            12-19-2024, 05:04 PM
          • EasyGoing1
            UPNP, "Standards" and hardware that implements it
            by EasyGoing1
            I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
            One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
            So I decided to implement UPNP...
            07-16-2022, 07:12 PM
          • mscottdoran@gmail.com
            Can anyone identify the classification of this data signal?
            by mscottdoran@gmail.com
            Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
            The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
            The boards are powered by a ground referenced...
            02-08-2025, 11:31 AM
