Ubiquiti Nano LocoM2. Not working, help
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Hi all
    Receive a warm greeting
    I have a LocoM2 unit.
    I presume that the firmware is corrupted since when turning on the computer it does not do anything.
    ¿Someone will have the original dump version of this computer?
    I downloaded a firmware from the official page, but it did not work. Now turn on some LEDs but does not respond.
    Record the flash with the CH341 programmer, since it was impossible to connect via LAN / TFTP.
    LocoM2
    Board: FR494 V-0 / E88551
    Flash Chip: Winbond 25064CVF1G
  • CapLeaker
    Leaking Member
    • 8040
    Re: Ubiquiti Nano LocoM2. Not working, help
    usually these things are purchased in pairs, also 2 of them at the same time. See if you can get the other unit, factory reset it, then copy the content. I haven't seen one that had corrupted firmware. If the winbond is good, I highly doubt the firmware is corrupt.
    what happens if you press the reset button? Make sure that button is good and not jammed (don't ask, I've seen that).
    • SoporteHR
      • Sep 2018
      • 80
      • Venezuela
      Hi.
      Thank you very much for your answer.
      I do not have the other unit, they only gave me this as a gift and for replacement, since it is practically dead.
      Turn on but there is no connection to the LAN. The LEDs do not respond as it should, nor does it respond to RESET procedures. Neither factory reset. That's why I think it's a firmware or memory problem.
      Thank you.
      • CapLeaker
        Leaking Member
        • 8040
        There are 2 different firmware's available for that LocoM2. Apparently there are 2 different boards. An XM and a XW board, each have their own firmware. Probe around the LAN port with an oscilloscope. Some LAN connectors have magnetics inside, or my best guess is the LAN chip itself is bad and needs replacing. Look at this example for an Atheros 7240: https://www.lan23.ru/forum/attachmen...0&d=1502374718
        • Jonsered2050
          • Sep 2019
          • Elbonia
          Simply connect a console (UART/whatever) cable and see how far it boots.
          • MaXwELL
            • Oct 2009
            • 14
            • Turkey
            CPU are bad
            Change AR7240 or 7241 and working again.
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
              SHUTTLE XPC nano NC1010XA XPC nano 4205U Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC nano NC1010XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010XA boardview and XPC nano NC1010XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:36 PM
              SHUTTLE XPC nano NC3000BA XPC nano 3865U Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC nano NC3000BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC3000BA boardview and XPC nano NC3000BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              SHUTTLE XPC nano NC1010BA XPC nano 4205U Specification for Upgrade or Repair
              This specification for the SHUTTLE XPC nano NC1010BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010BA boardview and XPC nano NC1010BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
