'unidentified network' for static IP systems
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I changed out a dying switch on my LAN. I have 2 servers on my network, the main NAS and the backup NAS which were both on static IP's. After the changeout, I could no longer RDC into the NAS....so after putting a KM/mouse and monitor on it, I'm getting this 'unidentified network' nonsense. I've tried all the bandaid fixes that google found....and there seems to be no cure. Doing the disable/re-enable bandaid, that fixes it until I reboot....then its back to the same unidentified network BS. If I enable DHCP, of course it's fine & dandy, but my NAS's have used these IP's for the last 17 years, I don't like change....and besides that, it was fine before. The OS is S2K12 R2, but also does this on Win7 systems. The network is otherwise working.....no bad cables, switches, etc.
    What is the fix for this? It's beginning to piss me off...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • 31087
    Re: 'unidentified network' for static IP systems
    makes no sense to me, most switches are transparent to the o.s.
    or did you install something "smart" ??
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      no, just a 10yr old 3com 48-port gigabit managed switch. Yes,I cleared its config back to default, and its just basically acting as a hub....nothing smart or fancy....it doesn't make sense to me either, and the network is working....just that 'unidentified network' BS for any machine with a static IP.
      Team : 49813
      Join in!!
      Team Stats
      • retiredcaps
        • Apr 2010
        • 9271
        If you tell us the IP addresses of the NAS, backup NAS, that will help.
        --- begin sig file ---
        --- end sig file ---
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          ^they're just internal IP's, not live. The router is 192.168.2.1, netmask 255.255.255.0. Nas1: .180; Nas2: .181.
          NAS1 is the LAN's DHCP server, which is working (systems on the lan are grabbing IP's from it)...using the router as the gateway (obviously).... I use google DNS (8.8.8.8, alt 8.8.4.4)....but as 'unidentified', it's refusing terminal service connections (RDC), and of course shared folders....the only way to "make it work" is to physically logon and disable/re-enable the NIC, yea, major PITA for a headless setup....or use DHCP. Yea, me is confused too.
          I think its just something really stupid that windows is doing/not liking the static IP's, no actual problem with the network. I swapped back to the old switch, I'm getting the same result.
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Ok, the temp fix seemed to be opening secpol.msc, and in the "Network List Manager Policies" category, change 'unidentified networks' from unconfigured (defaults to public) to 'private'...and I had set an identified network to be handled as a 'private' aka 'work' network. That seems to have made everything start working again....but the seat of my pants thinks it's just a bandaid....so if anyone has any other ideas, feel free to post it!
            Team : 49813
            Join in!!
            Team Stats
            • Spork Schivago
              • Mar 2012
              • 4734
              • United States of America
              With the newer versions of Windows (7 for sure, maybe Vista?) don't you have to tell the OS if it's a public, private, or work network or something like that?
              I know we use Symantec EndPoint Manager, before with Norton though, we had to "trust" the network in the actual Norton user interface...
              On this Windows 10 Enterprise E3 laptop, I would right click on the Wireless icon (I'm connected wirelessly, but I believe it's the same for wireless), then click on Open Network & Internet Settings -> WiFi -> Manage Known Networks (then I'd click the network, then go to Properties, and finally pick Private or Public).
              Setting to Private opens the Windows firewall to allow protocols like RDP through. Is that not what's going on here TopCat?
              -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
              • retiredcaps
                • Apr 2010
                • 9271
                Slightly off topic, but consider 1.1.1.1 to 8.8.8.8
                see
                https://1.1.1.1
                I can't help with any of the Windows stuff. I haven't run it of 4 years and counting, only the IP addresss and routing stuff.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  yea, but when its set static on a headless server, it defaults to 'unidentified network', which then defaults to the 'public network' setup, which basically locks it down. Changing that default from public to private fixed it....but its still showing as an inidentified network.....
                  see
                  https://1.1.1.1
                  Thanks for the tip, I'll try it.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Someone asked me in PM about DNS requests not being encrypted. I suggested dnscrypt
                    https://www.opendns.com/about/innovations/dnscrypt/
                    DNSCrypt turns regular DNS traffic into encrypted DNS traffic that is secure from eavesdropping and man-in-the-middle attacks.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      For anyone else interested, I could not find Linux instructions on that site, but did find many people are using it with Linux, or at least it's available for Linux.
                      I found this how-to, although it seems to be targeted towards Ubuntu users. I'm sure if someone isn't using Ubuntu though, they could probably figure out how to make it work on their distro. If not, I'd be willing to try to help them via the community forums here, as I'm sure other users would too.
                      http://www.linuxandubuntu.com/home/h...using-dnscrypt
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        NT 6x is known to randomly get stuck at "Identifying". (or similar) And that can occur, even if you just reboot.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          see
                          https://1.1.1.1
                          Just incase anyone is wondering or cares, this DNS service functions well.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • ChaosLegionnaire
                            HC Overclocker
                            • Jul 2012
                            • 3264
                            • Singapore
                            ah yes... opendns. i use opendns as the dns server for my dns lookups. these are the two opendns dns server ip addresses i use:
                            Code:
                            208.67.220.220
                            208.67.222.222
                            hope this is useful for anyone wanting an alternate dns server for resolving dns lookups.
                            • BOSCHNJAK
                              by BOSCHNJAK
                              ABOUT ME INTRODUCTION FILE
                              2
                              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                              2022 BEV, PROJECT ?
                              2021 BEV, PROJECT ?
                              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                              12-28-2023, 02:09 PM
                            • howardc64
                              Samsung UN55JU650DF network/streaming problem
                              by howardc64
                              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                              07-09-2025, 12:44 PM
                            • davg
                              Home network connection problem
                              by davg
                              I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                              03-06-2021, 07:13 AM
                            • japlytic
                              Maximum speed should be marked on network ports
                              by japlytic
                              I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                              One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                              12-19-2024, 05:04 PM
                            • harp
                              simple win network with optimization issue
                              by harp
                              simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                              06-23-2025, 11:01 AM
