Wireless access points and Local Network IPv6 State
  • japlytic
    • Oct 2005
    • 2086
    On a Technicolor TG800vac being used as a wireless access point (DHCP turned off and IP address not within DHCP range of another router), I had a problem where Android devices would not connect to the Internet (although they can access LAN resources OK) but a Windows PC did not have this problem.
    Some investigation revealed that the Local Network IPv6 State option which was enabled (most likely an IPv6 DHCP option), so I turned it off (and toggled Wi-Fi off and on on the Android devices) and this fixed the problem.
    • 31083
    Re: Wireless access points and Local Network IPv6 State
    no surprise most isp's dont support ipv6.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      That's what it looks like, even in the late-2010s! So IPv4 definitely isn't dead!
      It's even less likely to be dead for a good while, because of program compatibility! Halo CE has a strong fan-base and thus eliminating IPv4, likely will cause Halo CE to be extinct! And probably other programs, which are more important...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • japlytic
        • Oct 2005
        • 2086
        To clarify, the router for Internet access has DHCP enabled for both IPv4 and IPv6.
          • 31083
          doesnt matter, unless the router is set to translate between address-types it is just going to forward both out into the world.
          and as i said, most(all even??) isp's arent supporting IPv6 yet - hell it's grayed out in the router here.
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            I have had problems with android and windows trying to use ipv6 gateways to access the internet on non ipv6 internet connections so as a preventive measure I disable ipv6 dhcp servers
            My pc
            CPU : AMD PHENOM II x4 @ 3.5Ghz
            MB : ASUS M4A89TD PRO USB3
            RAM : Kingston ValueRAM 16gb DDR3
            PSU : Cooler Master 850W Silent Pro
            GPU : ATI Radeon HD 6850
