TP-Link TL-SG1008 Gigabit Switch - pre-emptive recap and fan upgrade
  • Agent24
    I see dead caps
    • Oct 2007
    • 4977
    • New Zealand
    I have a TP-Link TL-SG1008 I bought some time ago, second hand. I never used it because the fan was horribly noisy and I didn't need more than 100Mbit anyway.
    Now, I find myself needing the bandwidth. So I decided to look into the situation...
    I did a pre-emptive recap of all the crapcaps (may have been unnecessary, the thing runs really cool anyway) but hey, why not?
    I also replaced the original, noisy and worn, single fan with two new ones. Each of the new ones use half the power of the old, and make a fairly soft noise in comparison to the screech of the original fan.
    After putting it into service, I then discovered how trashy on-board Realtek chips are... and had to upgrade to some decent Intel PCI-E cards.
    -David VanHorn
  • tibimakai
    • Jan 2012
    • 3680
    Re: TP-Link TL-SG1008 Gigabit Switch - pre-emptive recap and fan upgrade
    I did this, to a TL-GS1008PE. I'm using it, with security cameras. I will need to pick up another one, or upgrade to a 16 port one(POE version).
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Make sure you do your homework wrt the PD's and PSE's before you get too heavily into POE. It seems like there are a variety of (incompatible) approaches to that problem (from all varieties of vendors!)
      You're also likely to find that many POE switches have their (PSE) power supplies sized for "telephone loads" -- i.e., 7W/port. And, may not be able to support ALL of the ports on the switch, simultaneously (so you may end up needing a bigger switch than you originally expected)
      Note, also, that some switches allow you to augment the internal power supply.
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Kingpin!
        3COM OfficeConnect Gigabit Switch 16
        by Kingpin!
        3COM OfficeConnect Gigabit Switch 16 (3C1671600)
        The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
        09-17-2023, 04:58 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
      • SluggerB
        Help making a switch work the opposite way with a relay
        by SluggerB
        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
        02-07-2025, 07:57 PM
