Cooling my Netgear Nighthawk C7001V protect.
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;check out this cooling project that i did to my router,it kinda was getting a little hot on streaming hd,(what i heard it's normal for this route}, i turn it on when streaming and turn it off when it's on just phone.and it works, it really gets really cool.See pic attach.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Cooling my Netgear Nighthawk C7001V protect.
    • ivtec
      • Dec 2008
      • 1967
      Originally posted by eccerr0r
      eccerr0r;778334; I know a misspelled (project} so what! if that's what you mean? i must admit you are a very funny man bro.
      • ivtec
        • Dec 2008
        • 1967
        And for wise guys i have here some good reeding and advice;
        https://itstillworks.com/netgear-wir...-12181306.html
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Nah, nothing wrong with your hack, just using what you have - ghetto or not - if it works, it's good!
          • greatdragon
            Looking for schematics for Netgear Nighthawk c7500
            by greatdragon
            The markings on the board say
            tmt YAML 1 94V-0
            e114139
            1806
            03-20-2025, 11:58 AM
          • Ace Perception
            Samsung R530 Bremen motherboard cooling
            by Ace Perception
            I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
            I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
            So I went in pursuit of...
            07-21-2020, 03:05 PM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
          • Hondaman
            Liquid cooling?
            by Hondaman
            I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
            (After previous generation hardware [Gigabyte] didn't...
            05-08-2025, 09:37 PM
          • gripa
            looking for netgear WN2500RP schematic
            by gripa
            I am looking for a schematic of the netgear WN2500RP repeater.
            best regards
            12-17-2024, 12:39 PM
