A factory reset may require multiple factory reset operations
  • japlytic
    • Oct 2005
    • 2086
    After I upgraded the firmware on my friend's D-Link DSL-2544N dual band wireless ADSL modem (to try to fix a problem with the 5GHz wireless network not showing up), the firmware update looked like it was performed OK, but I can no longer access the configuration pages and the DHCP server was not running.
    I tried a single factory reset procedure (press the WPS button for more than 15 seconds on this model – my smartphone with Internet access (which this procedure was obtained online) saved the day! ), which did not work for the first time , but a second factory reset enabled me to access the configuration menus .
    Of course before then, I noted the wireless and ADSL account settings before I did this.
    After re-entering the settings, everything was back up and running again, but the 5GHz wireless network was inoperative (most likely a loose connector or other hardware fault ), despite changing the channel numbers before and after the firmware upgrade and factory reset (even though the country selection was correct for the devices in question).
    I also had a similar situation with a dual-band Netgear WNDR3700 v2 bought at a local junk shop (a first for me! ) for a song, and I could not access the configuration pages (not even the password prompt), even with a wired connection.
    Three factory reset procedures later (holding the Reset button until the lights go strange), the Netgear is now working and is used to improve wireless coverage, especially in my workshop where I had problems with dropped connections due to poor signal strength.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: A factory reset may require multiple factory reset operations
    What firmwares are you running on these routers?
    For future reference, a 30-30-30 reset is pretty much universally required to get a full factory reset on most (if not all) routers. The procedure is with power on hold the reset button in for 30 seconds, remove power while still holding in reset button for 30 seconds, apply power while still holding in reset for 30 more seconds.
    I've had a similar ongoing issue with a Netgear WNR3500L v2 not getting to config pages after about 24 or less hours of up time while router functions are still working otherwise. My workaround has been to schedule a reboot every 24 hours but occasionally have to manually do a 10 second power cycle to correct. It is thought to be caused by a memory leak but monitoring memory usage does not indicate that. Radio on or off also does not seem to make a difference. I'm inclined to think it could be caused by something more basic like poor power filtering or EMI. I'm running DD-WRT v3.0-r27520M (07/17/15) kong firmware.
    • japlytic
      • Oct 2005
      • 2086
      The firmware on the two routers I mentioned had the standard stock (manufacturer-provided) firmware, and the D-Link unit was updated with an official firmware from their website.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        It is recommended you should do a 30-30-30 reset before and after a firmware flash. What I'd do at this point is a 30-30-30 reset and see if that fixes the issue. If not then do a 30-30-30 reset, re-flash the firmware update, and do another 30-30-30 reset.
        • mon2
          Hisense 55Q9G Android reset / factory firmware reload
          by mon2
          Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
          After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
          01-03-2024, 10:25 AM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • madan1
          Unbricking Vigor AP
          by madan1
          Good day.
          I'm posting this to help other people.
          If you have a Vigor AP with some kind of a software issue or just with an unknown admin password and disabled reset button, here is how you can flash a fresh firmware.
          Download the firmware from the vigor's website and extract it somewhere.
          Download TFTPD64 or other tftp client with file push.
          Connect to the unit with an ethernet cable and set your client IP address to 192.168.1.10 (just not .1 or .2).
          Start TFTPD64, go to tftp client tab. Select the server interface with the above IP and...
          06-18-2025, 02:32 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
