cable modem frequently disconnects
  • Captain Bill grace digger
    • Jul 2015
    • 70
    • India
    I have a problem with my cable Motorola modem. The model no is - SB5101i
    The problem is I am facing frequent internet disconnections each day for the past three months. The frequency of the disruption has just worsened over time. The first one and a half months I had to reset the coaxial cable for the modem to move on for another hour or two. Now the modem stays offline from late morning till early evening every day. During this time the modem tries to connect comes back for a few seconds or minutes then goes offline back again for a long time. So I am unable to use internet throughout the day.
    But the modem works fine throughout the evening. I am able to use internet in the evening. Can you please give me a nice solution to this problem.
    • 30979
    Re: cable modem frequently disconnects
    it could be capacitors in the modem or it's psu.
    but it could also be your cable supplier or the actual cable.
    • japlytic
      • Oct 2005
      • 2086
      Has the cable modem requirements of your provider changed?
      This is a DOCSIS 2.0 cable modem; could the provider now require DOCSIS 3.0 or later cable modems for their service?
        • Jul 2015
        • 70
        • India
        Actually the modem disconnection problem is not new. I have been facing this problem since the time I joined the ISP in 2008. This modem has not been changed since. The thing is that the disconnections were not so frequent and long lived like what I am facing now which is every day for the whole morning and afternoon. But today at afternoon the modem is luckily receiving connectivity. But this has surely not solved the problem.
        The ISP has many fiber cuts outages etc. problems. I do have technicians come over a few times to check the connection. They usually then go and do something to the cables in the locality and then the connectivity gets restored for a short while a few weeks or a month.
        A technician visited a few days back and told me he changed the RF modulator. This is the second time the technician has told me this. This time the connectivity was restored for only a few hours. The next morning modem had again lost connectivity.
        I also recently spoke to a manager from the ISP he told me it is most likely a signal issue
        For the first time from the past few days the modem is loosing connectivity every day for long periods of time the whole morning and afternoon and the ISP is not able to restore my connection.
        Is there a software that can test the modem to ensure it is working fine.
          • 30979
          does it have a webpage?
          what happens if you put the modems i.p. into your browser?
          • mathog
            • Mar 2010
            • 2655
            Heat?
            Cable modems tend to run pretty warm, and since it is August in India, one suspects that the operating environment may be very much on the toasty side. You say it is going off line morning to afternoon, and that would correspond more or less to the warmest part of the day. If your house has A/C then the problem could still be heat, but in the ISPs circuitry. Do your neighbors lose service at the same times, or is it just you?
              • Jul 2015
              • 70
              • India
              I have not activated the modem with the ISP as yet. I am connected through the Ethernet cable from router to my PC. It looks like the modem does not have a webpage. It only has a installation detection and user guide software on disc.
                • Jul 2015
                • 70
                • India
                May be the neighbors loose service too because most of the locality is connected to the came ISP and when ever I call these technicians most of the time they say work is being done in your locality, there is a fiber cut, there is a downtime in the locality or there they are experiencing a power loss.
                  • 30979
                  is mumbai effected by the regional flooding?
                    • Jul 2015
                    • 70
                    • India
                    Yes.
                      • 30979
                      could it be humidity when the sun is up then?
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        More traffic during the day on a problematic network and the weather isn't helping matters.
                          • Jul 2015
                          • 70
                          • India
                          No August is not a hot time in India specially in Mumbai where the current temperature is 29 centigrade this is a very pleasant time in Mumbai it is a time when Mumbai is still receiving mild rain showers. The hottest part of the year in Mumbai is from march to may where may is the hottest and it is during this time when the temperatures sore between 37 to 40 centigrade.
                          • TVRepairNoobie
                            • Feb 2015
                            • 158
                            Hope the ISP is lowering your rate for the terrible service.
                              • Jul 2015
                              • 70
                              • India
                              Is there any other solution besides relying on the service of the ISP.
                              • TVRepairNoobie
                                • Feb 2015
                                • 158
                                This perfectly explains your problem, I am sure there isn't anything you can do unless there is another ISP, hopefully with better service than your current one.
                                  • Jul 2015
                                  • 70
                                  • India
                                  Could it be a week modem signal problem. Because when I get disconnected the modem leads are still on. The power, receive and PC activity leads remain on and stable while the send led keeps blinking while online led stays off. The modem stays like this for an hour or so then comes online for a few minutes then goes offline again. It also looks like the modem tries to reset it self again and again. Because when it goes offline the power led starts blinking then receive led starts blinking then send led starts blinking. The modem then gets stuck on the send blinking led and cannot come online while the power receive and PC activity leads are stable.
                                  I have found a Motorola signal booster can this solve the problem here is the link please have a look :- http://www.amazon.in/Motorola-Signal...le+Modem+Boost
                                  • JollyGreenJoint
                                    • Aug 2015
                                    • 5
                                    • usa
                                    The modem access page is usually 192.168.100.1 for motorola surfboards. As others have said its usually a problem with the network and not your modem. Easiest way to solve is switch to a different network. You can check your connection by running a continuous ping from command prompt and look for lost/dropped/timed out packets. You can also run a similar test from dsl reports , "line quality test" http://www.dslreports.com/tools
                                      • Jul 2015
                                      • 70
                                      • India
                                      "Exactly" it is a problem with the network. The Motorola signal booster is a 15db cable/antenna drop amplifier. Which means if any one is having trouble receiving solid and reliable cable TV or cable modem signal should use it. It boosts the cable/antenna signal coming through the cable into the house so that one does not experience frequent outages on cable modems and pixilated (distorted) images on TV screens due to week signals.
                                      • CapLeaker
                                        Leaking Member
                                        • 8118
                                        Just to clear something up... That coax cable is going directly to your cable modem? No splitter etc in line?
                                        • Patch2
                                          Cable Repair
                                          by Patch2
                                          I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                                          01-02-2025, 06:04 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • fweonea
                                          HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
                                          by fweonea
                                          While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
                                          I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
                                          01-16-2024, 11:35 AM
                                        • marce002
                                          Help me make charger USB C cable with no cc pins!!
                                          by marce002
                                          Hi all, please
                                          I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
                                          How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
                                          NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
                                          here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
                                          thanks in advance!!
                                          11-17-2023, 09:16 AM
                                        • paparazzo79
                                          Hannspree HT 273 HPB USB cable type A to type B?
                                          by paparazzo79
                                          Hi guys.
                                          I purchased the monitor from the link below:
                                          https://www.hannspree.eu/product/ht-273-hpb/
                                          Since I will be using monitor from bed, I'd need longer usB type A to type B plug cable.
                                          I got one which is 4.5m long, regular one
                                          May I use it without harm to the monitor?
                                          I suppose cable which came with monitor is regular type A to type B,not some speical cable.
                                          I could picture what is labeled on the cable, if it matters for assistance.
                                          08-12-2023, 05:28 AM
