The device may not be present or have been ejected/unplurged from system. Isert or re
  • ciki
    • Aug 2014
    • 132
    • Ireland
    Hi I have asus x502ca and cant make wifi working try everything change card (3 different) try all drivers for atheros ,check bios ok ,fn+f2 works on off airplane mode,wireless lights is on but nothing there ,no wireless network adapter in device manager ,so I guess that something wrong in board anybody know what should I look what give power to wifi card ? visually couldnt find any broken fuse ,capacitor, etc .Should try to reflow ic chip or any suggestion
    thx
    And forget while trying to instal driver get message "The device may not be present or have been ejected/unplugged from system. Insert or reinsert now."
  • diif
    • Feb 2014
    • 6978
    • England
    Re: The device may not be present or have been ejected/unplurged from system. Isert o
    Try booting from a linux live cd like puppy or mint.
    That way you know it's hardware and not Windows.
    • aprilmixtape
      Asus FX516PC "No Storage Device Present"
      by aprilmixtape
      I recently flashed my Asus Tuf Dash F15 (2021) with a CH341a after having an issue with the laptop not booting for 2 years. After I had flashed the bios, I reinstalled my M.2 SSD that I had removed from the laptop when it stopped booting 2 years ago and booted it up, which took me to the bios instead of booting to the hard drive. In the bios, it says "No Storage Device Present". I turned off the laptop and tried using the other M.2 slot but had the same issue. I suspected the problem was that the SSD was dead so I created a USB Windows 10 Installer and plugged it into another Windows...
      12-21-2024, 12:00 AM
    • Yolofolkss
      Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
      by Yolofolkss
      Hi this is a really odd case.
      I have removed all of the esd ic for USB 3.0 and 2.0
      I measured all of the data lines and 5v usb voltage lines there are no shorts
      all of the USB ports have no damage
      Clearing the bios using the jumper wont help.
      it is still showing USB overcurrent device
      the only temporary fix I've tried and worked so far is flashing the bios
      and the error is gone
      but when you start the motherboard with a USB device still attached
      the USB over current device error is back. the bios needs to be externally flashed...
      01-09-2023, 04:21 AM
    • mrdevil
      Crest Smart Home Single Power Adaptor SHSPM1 (rebadged Tuya device) - bad cap causing failure, how to repair
      by mrdevil
      Wanted to share this as I couldn't find anything on the internet about this problem, so pulled one apart and found the problem myself. Years ago I bought approx 20 or so Crest Smart Home Single Power Adapter smart switches - small 240v Tuya-compatible (rebranded) smart switch devices with power monitoring, which Big W had on sale for half price. Paid $7.50 each for these, and they've been incredibly useful for turning things on and off remotely... and monitoring how much power each device uses.
      However, after about 12 months, I had a number of these stop working...
      01-08-2025, 03:19 AM
    • Stachujones
      Dell XPS 13 9370 unknown USB devices in device manager
      by Stachujones
      Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
      Device manager says "unknown device, failed to request device descriptor"
      Can somebody point me in right direction what to check?
      I updated bios to the newest version and thunderbolt controller firmware still no luck
      04-05-2025, 07:35 AM
    • Grouickman
      Hofmann geodyna 6300 Wheel balancer
      by Grouickman
      Hi there,
      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
      03-31-2025, 05:29 AM
