Inside an old Netgear Wi-Fi router
    A free PCIMIA NETGEAR card! Not some specialised one -- this is an ordinary laptop one... And held in with a cable tie...
    This is an ~7-8yr old 802.11b router.
    I suppose it's one way of getting a product out quickly!
  • luke10050
    • Mar 2013
    • 209
    Re: Inside an old Netgear Wi-Fi router
    well it works i guess, its not that bad of an idea either, a lot of the older ones had it, afaik it allows some upgradability of the modem? or was implemented to use the same PCB for a range of different cards
    • pentium
      • Mar 2006
      • 2778
      I love it when they do that.
      I pulled an HSPA PCI express card out of a cellular modem.
      Find Nedry!
      Check the Vending machines!!
      <----Computer says I need more beer.
      • japlytic
        • Oct 2005
        • 2085
        I found some wireless routers have a PC Card or Mini-PCI wireless card which did work in a PC; in some cases, the driver INF files needed modification to reflect the IDs on the hardware after identifying the chipset and getting the correct drivers for the chipset - it worked in most cases.
        Also, I found a USB dual-band Wireless-N dongle in a Telstra T-Box (Netgem 8000 series) and it apparently did not require modified drivers if I remember correctly.
        • Per Hansson
          • Jul 2005
          • 5893
          • Sweden
          The first Linksys WRT54G router was the same, had a MiniPCI WiFi card...
          http://www.linksysinfo.org/images/Co...RT54G-mblg.jpg
          • y_not
            Same 'ol Song
            • Aug 2009
            • 147
            I have some Netgear .g routers like that Linksys, with mPCI.
            WGR614 IIRC.
            I had no idea the original WRT was that way. CWAAAZYY! LOL
            I had a client with an old .b Netgear in their business class metal case, just like the one pictured.
            I had opened it up to see if I could detach the antenna so I could disable his Wifi. Silly thing didn't have a soft switch for that in the web GUI.
            How to properly apply thermal grease - Y_not's way.
            • ishelly404
              Captastic!!
              • Sep 2012
              • 21
              I found an old Belkin router with a similar arrangement. It had a PCMCIA (looking) card plugged into the mainboard and an external antenna connector.
              But when I took it out and tried to use it in two laptops, it didn't recognize on either one. I put it in the router again and it worked fine, so I would assume it isn't PCMCIA compatible or some of the pins were switched around, possibly to stop anyone from reusing it?
              • Hemingray
                KABOOM!
                • Jul 2010
                • 143
                Someplace here I have an old Dell Truemobile router that's like that. Even has a serial port on it for hooking up an external modem?
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  The serial port is most likely a console port for configuring it.
                  Ludicrous gibs!
                  • Hemingray
                    KABOOM!
                    • Jul 2010
                    • 143
                    I'd have to dig it out after I move, it's currently packed up.
