Intel 2200BG issues
  • stevo1210
    • Oct 2006
    • 4156
    Intel 2200BG issues
    Got the shits with three laptops here using the Intel 2200BG wireless card.
    Basically they worked well before when I was using a WRT54G as my router with WPA/TKIP 128 bit encryption. My WRT54G went belly up after I moved house so I replaced the WRT54G with an all-in-one ADSL 2+ modem & wireless router setup from D-Link.
    My new all-in-one unit is a D-Link DSL-2740B, it's a wireless N router as well.
    So far I've set my channel to 12 and to 802.11g mode only and it still doesn't connect to Wi-Fi.
    What happens is I'd double click on the network, enter the passkey and wait for it to connect... instead it won't connect and says "Windows is unable to connect" and that's it. Happens on all 3 laptops with the 2200BG (2x XP and 1x Win 7)
    One time I tried connecting my Sony Vaio UX handheld under Widnows XP and it asked me for a WPS key. I ended up going to WZC and it would connect using a normal WPA-PSK key.
    All other PC's that don't use this model of wireless card work with no problems at all. What is going on here?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Intel 2200BG issues
    whats wrong is something inherently wrong with that intel wifi card.
    I can't tell you how many times i've had connection issues with a 2200bg cards. mostly what i've experienced however is AP dropping issues. But the 2200bg is a terrible card across the board for multiple reasons
    I would have to say update your drivers, and HOPE that fixes it.
    a problem you might run into is some laptops will ONLY take intel cards, some won't even boot with another card in there
    but if yours can, I would recommend broadcom or atheros
    • stevo1210
      • Oct 2006
      • 4156
      I have a thinkpad t43, I don't think it takes anything BUT intel 2200 bg cards from IBM :-/
      • stevo1210
        • Oct 2006
        • 4156
        I'm getting desperate, so I'm gonna order another Linksys WRT54G off eBay and daisy chain it to the D-Link because I know these intel cards worked with the WRT54G really well... besides this method might also solve the wireless reception issues in my new home which is 3x as large as the old house (have many dead zones + complaints from other family members).
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          There is a workaround. For your model there is a 3rd party hacked BIOS that allows the use of different wifi cards. I cannot remember where they are but they do exist.
          sigpic
          (Insert witty quote here)
          • stevo1210
            • Oct 2006
            • 4156
            They do, but I'm not game enough to hack my BIOS... I'll probably brick it or something >.<
            On another note, I just turned off WPS on the D-Link... but haven't tested if this works yet for the 2200BG.
            • stevo1210
              • Oct 2006
              • 4156
              Well... plugged in the WRT54G and made a daisy chain with a bit of tinkering with IP addresses and so forth. Now the 2200BG cards all work... and I can finally get Wi-Fi reception out the back of the home!
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                No, its just a file that you reflash it with. Same procedure as a BIOS upgrade.
                sigpic
                • stevo1210
                  • Oct 2006
                  • 4156
                  I know that, but knowing me... I'd probably screw that up as well. I think the ONLY thing I've ever been game enough to flash was my Dell Inspiron 6400 which was still under warranty. When I have something under warranty I'll flash every single update onto it. :P
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    I've had this trouble before.
                    Here's what you have to do (assuming you're running XP, ignore this for any other OS)
                    1. Update XP to SP3 with ALL the latest updates
                    2. Install the latest Intel driver from the Intel.com website
                    This works for the 2100 and the 2200 cards, both of which are pretty crappy until this is done!
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      its pretty foolproof given that you do it under AC power.
                      sigpic
                      • shadow
                        • Feb 2007
                        • 732
                        Have to agree there.
                        I also love how the WRT54g has a JTAG port on it. Even if you completely trash the firmware, it can be recovered without any sort of issue. Now if only all electronic equipment came with a JTAG connector.
                        • EazyBone
                          Samsung The Frame TV no power indicator issues diagnosing the one connect box
                          by EazyBone
                          I got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
                          I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
                          While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small...
                          07-28-2024, 04:46 PM
                          HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                          This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                          09-06-2024, 03:30 PM
                          HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                          HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                          HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                          This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
