PEAK Powerline Adapters type 159814NRPK
  • kutchka
    • Nov 2011
    Firstly, I am new to this forum, I'm an IT & networks expert but I know nothing much about electronics though I can pull a board with brilliance (LOL) and I can wield a soldering iron.
    I have several of these PEAK Powerline adapters [100-240V 50-60Hz] (been working for over 2 years) that have all failed within a few weeks of each other and I am convinced that this is as a result of capacitors gone bad. (there are 2 obviously well domed marked C3 & C10).
    I haven't removed these domed (& doomed) caps yet to see their value but I'm wondering if anyone has come across these particular devices and could offer me any advice before I start.
    Maybe there is insufficient information here for anyone to help but at the moment I don't know what other things need to be mentioned.
    I'd appreciate any comment.
    Graham (UK)
  • seanc
    • Nov 2008
    • 1319
    Re: PEAK Powerline Adapters type 159814NRPK
    Hi Graham,
    I bought a pair of these from Dabs a couple of years ago.
    One day, I plugged one in and noticed it squealing.
    Opened it up to find bulged caps.
    I replaced the caps in question in both and they've worked fine ever since. They run quite hot.
    Contents now:
    C3: 220uf 25v Panasonic FM
    C4: 47uf 50v Panasonic FC
    C10: 1000uf 6.3v Panasonic FC
    C11: 220uf ?v Panasonic FC - I can't see the voltage. I would guess at 16v.
    Both work fine.
    • kutchka
      • Nov 2011
      Hi SeanC,
      Thank you so much for your swift response.
      I'll get on to RS Comps tomorrow and order the caps.
      Graham
      • kutchka
        • Nov 2011
        Hi SeanC,
        Got called away on business so haven't had a chance 'till now to review caps.
        I have removed the caps on my unit and they are:
        C3: 220uf 25v
        C4: 47uf 25v
        C10: 1000uf 10v
        C11: 220uf 10v
        Slightly different to yours.
        All are SC 105 deg TEAPO
        Any further comment (from anyone) before I proceed would be gratefully received.
        Graham
        • seanc
          • Nov 2008
          • 1319
          The ones where I've upgraded the voltage will just have been me using what I had around. You can go up in voltage with no problem - it's just how much voltage the cap can handle.
          I'm not sure what's going on with the 1000uf 6.3v... I guess I measured it with a multimeter and found it was 5v or less... you could measure yours and see. I've been using them for nearly a year now and they've not exploded.
          Mine were all Teapo as well.
          • kutchka
            • Nov 2011
            Hi SeanC,
            Thanks again for your comment and advice.
            I don't think that my C10 was measurable considering the state it was in (and worse, it fell apart on removal).
            I shall go for the voltages as they read on the caps; especially considering size is all important to fit in the limited space.
            I hope to be mentioning here my success with this project soonest (and I shall be honest if I fail).
            Graham
            • Doesronnieevenlift
              Help a noob! Wson8 Pogo/Needle Adapters to read/Write
              by Doesronnieevenlift
              I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
              My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
              I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
              For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
              Apologies if this is the wrong subcategory....
              06-22-2025, 04:51 AM
            • lapfix
              Dell latitude 5320 South peak 13 not power on.
              by lapfix
              Hello friends
              Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
              motherboard south peak 13 mb 213252-1
              i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
              i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
              As i undestand from many topic here ,...
              04-29-2025, 06:22 AM
            • Green Probe
              Latitude 5530, 203102-1, South Peak 15 MLK MB DDR4, i5 12th Gen
              by Green Probe
              Hi, I'm looking for a schematic and/or boardview for a Dell Latitude 5530. The motherboard is marked "South Peak 15 MLK MB DDR4, 203102-1, FK8VG$LA" I think it's the i5 12th Gen. I'm trying the similar 5520 schematic, but things are shifted around, making it a bit tough for me to find things. This might not be the place to discuss the issue, it shows no life. It consumes 5V1A when plugged into the USB-C charger. Main rail is present at 16.75V, and 4.2V is present at some locations. Any help is appreciated. Thanks!
              08-15-2024, 05:47 PM
            • expertreader
              Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
              by expertreader
              Hi, Looking for schematics and boardview please. laptop detecting only 5V at USB C so hoping for a short circuit....
              10-18-2025, 09:44 PM
            • eccerr0r
              common SATA adapters that support SAS?
              by eccerr0r
              Anyone know of common SATA controllers that support SAS? Perhaps all I'd need is one of those SATA-SAS adapters and one of these controllers?
              Else will I have to get a SAS backplane and dedicated SAS card and all to access a SAS disk?
              Wondering about how I can use this one 146GB 15K RPM SAS disk I have. Disk was free, if infrastructure will cost $ARM$LEG then I may well just put the disk in the trash (or wait until someday I get a machine with a SAS backplane...)
              09-20-2022, 08:50 PM
