Making a sort of Agree and Continue upon joining network...
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Hello!
    So I just set up a sort of guest network for my apartment building.
    But I want to know how to do like they have at school:
    Once you join the (unsecured) network it takes you to a login page where you need to supply a username and password before you can use the connection. Once you've sucessfully logged in all network services work like normal.
    How would I do this?
    Thanks!
    I'm using a Linksys 54G v.6 router with DD-WRT...
    Overclocked Broadcom CPU from 200Mhz to 225MHz, and boosted Tx power from 71mW to 150mW...
    To compensate increased power draw I used a Linksys 12V 1A power adapter instead of Linsys 12V 0.5A...
  • EagleTG
    • Jun 2011
    • 21
    Re: Making a sort of Agree and Continue upon joining network...
    I haven't tried it personally, but this is probably somewhere decent to start:
    http://www.chillispot.info/
    These are generally called wireless access servers, you could also use the keyword "hotspot" in your searching.
    Edit: More info for configuring DD-WRT with Chillispot: http://www.dd-wrt.com/wiki/index.php/Chillispot
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Ah thank you very much! That is exactly the sort of thing I was looking for!
      Now if Chillispot didn't have such an UGLY website, but that's the least of my worries... LOL!
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        captive portal would work too.
        I use it to stop infected machines using my internet while allowing the connection some privileges. For example it can't get on the internet unless I provide it some credentials but has access to my file-server, pxe boot server, and Windows Server Update Service.
        • howardc64
          Samsung UN55JU650DF network/streaming problem
          by howardc64
          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
          07-09-2025, 12:44 PM
        • davg
          Home network connection problem
          by davg
          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
          03-06-2021, 07:13 AM
        • japlytic
          Maximum speed should be marked on network ports
          by japlytic
          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
          12-19-2024, 05:04 PM
        • iMuhtaseb
          [SOLVED] 820-00165 corrupted network of some sort
          by iMuhtaseb
          [SOLVED] -- I came in this morning and I installed the AirPort screw with a little push and it resolved the issue.
          Hello everybody!
          I hope you all having a great day.
          820-00165 came with a black screen problem; the computer would operate normally but sometimes it gets stuck in a black screen for some reason..
          (I did not verify this issue when I turned on the computer until later on)
          After disassembly and doing visual inspection I found Q1840 and U1845 had some corrosion on it and around it.. from the schematics I understood that this...
          06-30-2021, 12:54 AM
        • hikomalek
          SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
          by hikomalek
          Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
          When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
          Transformer:
          |Info| Primary | Aux | AB | CD|
          |Ratio|1|25|40|12|
          |Voltage AC|230V|9.2V|5.8V|19V|
          |Voltage DC (*1.41)|230V|13V|8.1V|27V|
          I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
          09-19-2025, 03:30 AM
