CNet Cgs-500
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    CNet Cgs-500
    Found this at the garbage dump - one of the Wendell caps has vented.
    I can not find datasheets for wendell caps at all, also they have no series markings and is only marked as Wendell, uF, volts, vent 105.
    The cap that has vented I'm gonna replace with an fm, also for the 3 470uF that has not yet vented I have 3 Sanyo wx.
    Will the wx series do this job ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Re: CNet Cgs-500
    It's working perfect now.
    Replaced the 4 Wendell caps with fm and wx.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: CNet Cgs-500
      they should be fine.
      • mubeen14355
        Gigabit Gtx 980ti garbage display
        by mubeen14355
        Hello please anyone help me out
        I have a Gtx 980ti gigabit graphics card The problem is that without installing drivers display is fine but when I trying to install drivers drivers installation failed and garbage in display appears picture is attached...
        03-04-2022, 12:43 AM
      • mubeen14355
        by mubeen14355
        I have a Gtx 980ti gigabit graphics card The problem is that without installing drivers display is fine but when I trying to install drivers drivers installation failed and garbage in display picture is attached...
        03-04-2022, 12:21 AM
      • notallbad
        Indesit vented tumble dryer control board dead
        by notallbad
        Anyone able to help diagnose the fault with this board please.
        Hopefully photos are clear enough to give me direction on what readings to take and where.
        All ancillary components of the dryer have been tested and work i.e heating element, thermostats, sensors, motor, door switch, wiring harness.
        So theres 230v at the control board but no life whatsoever with or without the ancillaries connected.
        The on/off/timer dial contacts are clean and make good contact. All the through hole mounted components appear to be good i.e diodes, resistors,...
        01-04-2023, 05:49 AM
      • triplefour
        JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
        by triplefour
        got this tv from a friend who got a new one and didnt want to bother repairing this one.
        he said it sometimes would just flash color patterns.
        and sometimes it would just work
        i figured it had some intermittent mainboard issue.
        i stored it at home for a while before looking at it
        when i plugged it in for the first time, i heard some popping noises
        and then a big cloud of white smoke came out of the back of the tv!
        i noticed the smoke didnt actually smell like anything. not like when an IC blows.
        i unplugged it and took the back off and discovered...
        12-18-2022, 12:38 AM
      • nmantas
        Nichicon radials without the X vent?
        by nmantas
        I recently bought some Nichicon caps on eBay (yeah, I know). These are small 4x7 radial 16V 10uF caps. I feel they are fakes because the plastic pattern on the bottom and they don't have the X-vent stamped in the aluminum end and all the datasheets I have read indicate there is a vent(not exactly sure what series they are....or are supposed to be). I don't really care about the couple dollars wasted but when I let the seller know he thought they were real and he doesn't want to sell fakes. I thought I would do a little research and let him know. Is the lack of the characteristic X enough to prove...
        02-15-2019, 08:00 PM
