how to get rid of wifi mooches
  • PlainBill
    replied
    Re: how to get rid of wifi mooches
    so what do you want me to do? sledgehammer my wireless b cards and my emac?
    That sounds harsh, doesn't it? Think of it, however.
    You had a parasite leeching off your network. As you say, it was someone with a low skill level. Consider the implications of it having been someone more skilled - at least aware enough to match network names. You'd still be supporting the parasite.
    Now go one step further - a downloader. The latest Harry Potter movie went on sale today. Want to bet a rip of the BluRay disc isn't already available? How about someone with an appetite for music?
    How long do you want to depend on the lack of skills of your neighbors?
    PlainBill
  • digge
    replied
    it also was going to have access to the fileserver...
    VPN could solve that, but the more security one wants the more complexity it adds. Not really user friendly anymore
  • NxB
    replied
    Firmware update to support wpa? My B cards all support it, even the old ass ones. Otherwise get $5 cards from china.
    Or you can leave it all open/use wep. Its your shit.
  • ratdude747
    replied
  • digge
    replied
    This is what i would do, however I'm not sure its a viable solution in your situation.
    I would set up two wireless networks. One b network thats crazy locked down all the possible ways you can, and isolated from your other normal network so that it cant reach your local network, only internet. And a second g/n network thats more openly configured but with WPA 2 with AES encryption for the rest of your computers.
    Not sure if only internet access is whats needed for your emac and stuff so might not be a viable solution for your particular situation. Also there is of coarse the cost of doing all this as well.
  • ratdude747
    replied
  • kikkoman
    replied
    the kid porn scenario is much less likely than someone simply downloading pirated stuff (over BT etc.) via your connection.
    in some legislations you're the one who's screwed if you don't use WPA/WPA2 against better knowledge.
  • NxB
    replied
    The only real way to lock down is WPA/WPA2 with strong password, PERIOD. But I don't think its as bad as you say PB.
    financial activities over the neighborhood
    SSL takes care of most of this, you won't be broadcasting anything important.
    But take note of this:
    If you're using windows and some wireless networks are set to auto, the laptop will probe them repeatedly. If someone is listening they will see every network you've been using. Some people have wacky stuff broadcasting like phone numbers so make sure your laptop doesn't do this. Don't set any networks to connect automatically.
  • PlainBill
    replied
    My suggestion is to lock any wireless signal down as tight as possible. First, you don't want to be broadcasting your browsing and financial activities over the neighborhood. Second, you don't want to have someone else hogging your bandwidth. Most important, you don't want to get a visit from some policeman asking about the 5 gig of kiddie porn that was uploaded from your IP address.
    PlainBill
  • ratdude747
    replied
    yeah... i see. my goal was to have a one power cord solution. since the broadcast off feature seems to have stopped prettygirl, i see no reason to fix stuff that ain't broke.
  • DOS-man
    replied
    I think the easiest way to upgrade the wireless connection on your eMac would be to get a wireless bridge. Probably the easiest way to get a bridge would be to get a router with DD-WRT and set it up to be used as a bridge.
    http://www.dd-wrt.com/wiki/index.php/Client_Bridged
    I've never done that myself, but I've used the Linksys WGA54G and the Trendnet tew-647GA wireless bridge devices and I've found them to work well.
  • Scenic
    replied
    how i understood it:
    2 LEDs for his 2 computers via LAN were on, she parked outside with her laptop and the W-LAN/WiFi LED turned on when there shouldn't be any activity..
  • Pyr0Beast
    replied
    <i>SInce I had two PC's online at the time two of the green lights should have been on.</i>
    Hm?
    The only 'modem/router lights' I know are for LAN port activity and wireless activity.
    Without any advanced scripting those lights don't show the number of connected clients
  • kaboom
    replied
    No it's not illegal. If she don't like you monitoring after she busted your security, no matter how weak it is, she best 'keep her RF off your property.'
    Just like when people build their own FM SCA decoders and the old media complains.
    "HOW DARE you listen to what we normally charge for!!!" The FCC is on your side and ConglomoClearChannel's RF *GOES EVERYWHERE!* And I'll go back to the 'home recording' days. Your signal is traversing my property, my radio 'just happens' to be on frequency and I'll have MY 'back up' of this broadcast, damn the torpedoes.
    Not quite the same thing, but who the hell has the nerve to steal your bandwidth, then hack when you've had enough, and finally play double standards?! Besides, it's PRIVATE PROPERTY and the little bitch is SOL- she doesn't even have the same imagined 'rights' that she'd have at a hotspot.
    If she needs it so damn bad, she can get a PCMCIA broadband-over-cellular card.
    -Paul
  • Wizard
    replied
    japlytic wrote:
    A growing number of wireless access points and clients (including Intel) will not allow connection speeds faster than 54 Mbit (G) if WEP or TKIP is used.
    I'm not familiar with TKIP, but I am with AES, a high-grade encryption standard.
    Where did you find that out?! Documentation did not say this.
    Cheers, Wizard
  • japlytic
    replied
  • Junk Parts
    replied
    I wouldn't even know where to look in my OS/Network to log/sniff the pockets. I caught her the easy way. I saw her. When I look out the window to the left of my desk I can see the road and curb outside as well as my modem router sitting on the stand. She was parked at the curb with a laptop in her lap. SInce I had two PC's online at the time two of the green lights should have been on. At the moment I looked outside and could also see the modem a third green light came on. It was her jumping on. If she had been nice about it when I confronted her I wouldn't have had any problems with her using my hot spot for her work when she was in the area. I wouldn't want the police to take her lappy ether. She makes her living with the thing.
  • NxB
    replied
    If it was starbucks and you logged her packets from another client then that would be illegal.
    Furthermore a photo of her sitting outside. PD seizing the laptop (chain of evidence) + subpoenaed ISP log (chain of evidece) would make it a slam dunk case.
    The defense would try to get your log thrown out and because of the other 2 it would fail. The only hurdle would be incompetent police or prosecutor not wanting to pursue charges.
  • digge
    replied
    Logging/sniffing in your own private network cant be illegal can it? If it was a public network for the purpose of giving out internet then yes, that might be illegal. But on a private one you can tell whoever asks permission that its monitored and all that and they can choose not to connect if they dont trust you.
  • NxB
    replied
    How so? She is hacking into your network. The traffic would be recorded as evidence. This is after they have had words.
  • howardc64
    M557-G0 no WiFi/Bt no WIFIVendor file?
    by howardc64
    Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
    • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
    • Service Menu shows many Bt/Wifi info missing
    • Vizio app shows no WIFIVendor file
    Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
    • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
    10-15-2024, 01:12 PM
    HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    09-06-2024, 03:30 PM
    HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
    This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
    HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
    This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
