Synology ds415+
  • H1ghl4nd3r
    • Jun 2020
    • 39
    Synology ds415+
    Got another synology ds415+ was told that it is just flashing blue power light.
    Opened it up and found residue of a previous resistor fox that had been removed and cleaned up a bit but under the microscope it shows
    I did the resistor fix twice just to be sure but all I get is the blue power button flashing for over 20 minutes each time until I power it off.
    Anyway I changed the power supply for a known working new and same problem also replaced the cmos battery
    Only thing I can think of is a possible problem with the memory stick it's oem so not sure this is the problem
    Any searches always come with resistor fix or replace the power supply but don't think it is these
    • 31094
    Re: Synology ds415+
    you really need to stop getting these synology shit.
    some of them have an Atom cpu with a design fault in it that causes slow failure - just thought i'd point that out
    • H1ghl4nd3r
      • Jun 2020
      • 39
      Re: Synology ds415+
      Yeh I come across these now and again, but this was supposed to be an easy fix �� but as usual people are vague and lie, I haven’t heard of a resistor fix not working before, I did it twice just incase, will look at the memory stick later and maybe look at the cpu itself, but will have to find some info on the chip
        • 31094
        Re: Synology ds415+
        if your resistor fix is the cpu clock then it probably just finally killed the fet inside the chip
        the resistor puts extra strain on it
        btw, i know you know this, but people always say "it's an easy fix"
        if that where true they would have fixed it themselves.
        it's like all the shit on ebay sold as "untested", which is code for 6 people tried to fix it and now it's fucked
        • gokhan338
          SYNOLOGY DS415+ EDI42L2 V1.5 BIOS
          by gokhan338
          WORKING SYNOLOGY DS415+ EDI42L2 V1.5 BIOS...
          01-22-2025, 02:20 AM
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
