Recaping Linksys WRT54G v1.0
  • daemon123
    • Jun 2010
    • 50
    I have this old Linksys WRT54G v1.0 unit which uses 5v 2am supply.
    It was ok for a year but a few months back, it took like 4 to 5 mints to boot. the lights came up and down. i thought it was psu problem but i didnt replce the psu. Now its does the same thing but takes like 15 to 30 mints to boot.
    now tested it on another good PSU and the result is same, so i suspected the CAPS and opend up the router. The caps look physcaly fine but would like to replce them anyways. can u guys give me some alternatives to it.
    here are the caps.
    2x 1000uf 16v HERMEI LE 105c 0310
    3x 220uf 16v D-Paston TRS105c
  • c_hegge
    • Sep 2009
    • 5219
    Re: Recaping Linksys WRT54G v1.0
    Panny FM or FK should do the job. What country are you located in? That way, me or someone else could tell you a supplier.
    • daemon123
      • Jun 2010
      • 50
      thanks for quick reply.
      I am in Pakistan, if u remember i posted few months back abt bad caps in 8600gts video card. Online purchse is not posible and i will be going for salvaged parts. i think i had seen some 1000uf 16v in P3 mobo, will try to put those on. could u also tell me series which i can use from other like Nichicon and others
      • retiredcaps
        • Apr 2010
        • 9271
        Before you replace the caps, try this.
        Once the router is up and running, reset it back to factory defaults. Leave it off for about 15 minutes and then try powering up again.
        Also look for bad solder joints on the board.
        --- begin sig file ---
        --- end sig file ---
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Check voltages on the caps.
          They are probably actually on 5v or less which gives you more options in replacements.
          Mann-Made Global Warming.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I was in Pakistan in the mid '80's.
            Only place I ever saw a dump truck built out of a camel.
            I had curried yak. - It was GOOD!
            I remember they were kind'a freaky about technology things.
            One could trade a $10 calculator for $500 worth of stuff back then.
            What exactly is the restriction on you to buy from out of the country?
            - Dr Seuss
            • daemon123
              • Jun 2010
              • 50
              No restriction, but i am student and the cost is much higher to get stuff online here, so like it will cost 14 euros to get the stuff here, and i think the same type of new unit will cost 25 to 30 euros.
              And i have access to old mobo's, so salvage is best for me, i can get new parts from shop but they are very bad quality parts.
              • daemon123
                • Jun 2010
                • 50
                Things changed with time my friend, some can even rip you off by selling u something for 500 which would of had cost 100 .
                no more Camel Dumpster (wish i could of seen one ).
                Yak == horse ride ?
                Alot the new things sold here are 3rd Quality chiense, cant blame chiense for that, as the person that import them order the lowest quality cheap things.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Yak - A rather homely cow like creature.
                  http://en.wikipedia.org/wiki/Yak
                  - Dr Seuss
                  • bgavin
                    • Jan 2007
                    • 1355
                    Please post the diameter and approximate height. Thanks.
                    • daemon123
                      • Jun 2010
                      • 50
                      hi,
                      2x 1000uf 16v HERMEI LE 105c 0310 (dia 10mm, height 20mm)
                      3x 220uf 16v D-Paston TRS105c (dia 5mm, height 10~11mm)
                      • daemon123
                        • Jun 2010
                        • 50
                        found these, are they any good
                        2x Rubycon 1000uF 16v ZL TO232 105c
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          HERMEI LE 1000uf 16v are 1520 mA / .030 Ohm
                          Rubycon ZL 1000uF 16v are 1820 mA / .023 Ohm
                          - So that's an excellent choice.
                          - Dr Seuss
                          • daemon123
                            • Jun 2010
                            • 50
                            Hi
                            Found these new caps for the 220uf 16v. are they good ?
                            1. 220uf 16v nichicon VR(M) 85c M9847 (same size)
                            2. 220uf 10v CE 85c S044 (with symbol L on it)
                            the 2nd ones are smaller but wider.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Both are only 85C and the 2nd is 10V. 10V might be sufficient for this application, but you should measure the voltage on the board to make sure it doesn't go beyond 10V.
                              Why not just get Panasonic FC
                              http://search.digikey.com/scripts/Dk...name=P11199-ND
                              or Rubycon YXA
                              https://www.badcaps.net/store/produc...products_id=53
                              • daemon123
                                • Jun 2010
                                • 50
                                What if i had to chose from the above two only ? which one will be a good candidate
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Well, if you had to choose with no other option, I would go with #1.
                                  • daemon123
                                    • Jun 2010
                                    • 50
                                    thanks retiredcaps,
                                    i will try to find other caps too, and if cant find something better than will go with Nichicon
                                    • daemon123
                                      • Jun 2010
                                      • 50
                                      got the router working again, but it was not the bad caps, it was some kind of short in the mini pci express card it had. Gave the Mini PCI card a hot air treatment and its stable now. Thanks again for you help.
