GIFA Industrial TM-J3355-2G2L (Terramaster F2-221 NAS)
  • GoodCapacitor
    • Jun 2022
    • WWW
    Running out of options, my NAS has decided to stop working.
    After poking around I have noticed that SPI flash does not respond to read attempts (verified with 2 different programmers).
    The board uses 1.8v Winbond W25Q64FW. I would seriously appreciate if someone could help with a dump that can be used to revive the machine. Then I can purchase the new SOIC chip, flash it and replace one currently soldered to the board.
    Fingers crossed!
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • lapot2
    The Best and Fastest BIOS Flasher for Modding Under $2
    by lapot2
    Recently, the Raccoon Flash Explorer programmer has appeared.
    It allows you to flash BIOS chips from any device without installing programs and drivers, and also very quickly make small changes without a long rewrite of the entire memory to change a few bytes.
    Very easy to use and intuitive, even a housewife can handle it.
    You can use absolutely any system binary file editor (HxD, WinHex, etc…) on any operating system, the possibilities are not limited by the ugly built-in editor like other programmers.
    It has full cross-platform support, works...
    04-21-2025, 09:37 AM
  • spmetroil
    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
    by spmetroil
    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
    I have a CH341A programmer and I already attempted the following steps:
    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
    08-19-2025, 09:23 AM
  • abajor
    Canon VIXIA HF S10 A read data from inernal flash memory.
    by abajor
    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
    I think my best shot is to figure out a way to read the internal flash memory outside...
    07-20-2024, 12:04 AM
