Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
  • Boregy
    • Dec 2010
    • 21
    #81
    Re: Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
    Thanks for the links.
    One more question, are the cap specs always printed on the caps? I'm looking at them but I don't seem to see them in any of my pics, how do I figure out their specs?
    Edit:
    I notice both me and Renesis13 have the same 2 caps bad in the same locations...coincidence?
    https://www.badcaps.net/forum/showpo...24&postcount=6
    https://www.badcaps.net/forum/showpo...2&postcount=15
    • retiredcaps
      • Apr 2010
      • 9271
      #82
      The specs should be on every cap. It will say something like 470uF 25V.
      As many have already commented on the poor design, the heat kills the caps. So it isn't a surprise that the same caps are bulging.
      --- begin sig file ---
      --- end sig file ---
      • JoseJX
        • Dec 2010
        • 7
        #83
        Hi everyone. As a follow up, I've kept the case off my monitor since I wrote my first post. Today, it started to flick on and off again. I'll probably replace all of the smaller caps in the power supply, but leave the large filter cap and the caps on the inverter board. I'll update again when I get a chance to get it done, thanks for your suggestions. Any idea of the best way to remove the gunk under the capacitors as well? I assume it's a glue or epoxy.
        Also, with the poor power supply design, would it be worth trying to modify the heat sink as well? Any suggestions there?
        • MrOldboy
          • Jan 2011
          #84
          Hi this is my fist post here, but I have the same issue I believe.
          I've opened the monitor, but none of the capacitors look like they are bulging at all. One thing I do notice is there is a constant clicking coming from the power supply when plugged it. Its random about 2-4 times/second.
          If the capacitors are not bulging can they still be bad. I had the flickering on/off issue before it died a while ago.
          • Rtech
            • Jul 2010
            • 1095
            #85
            The Power Supply is obviously trying to start,hence the clicking.Caps don't need to be bulging to be faulty,an ESR meter is cetainly the best piece of Test Kit in these situations,but if you have not got one,then perhaps the initial and possibly the cheapest solution would be to change ALL the electrolytics on the board,except the largest one,usually in the 100uF,400v range,and take it from there.Dependant on your location in the World, there is lots of info on this site for the range of caps you will need and also some Suppliers.
            • retiredcaps
              • Apr 2010
              • 9271
              #86
              The clicking is the power supply trying to start like Rtech explains.
              The smallest capacitor next to the SMPS plays an important part in the startup process and can be bad without signs of bulging.
              This cap is usually in the 22uF and 50V range (as a guess). Replace with something like Panasonic FM or FC.
              • MrOldboy
                • Jan 2011
                #87
                Ok, I'll look into replacing that one cap, then move on to the rst if its does not work.
                • jjpjimmy
                  • Jan 2011
                  #88
                  I've found this thread through google, and I have the same monitor. I'm wording how you got the panel separated from the back plastic.
                  I've got the front cover removed, but I can't find a way to remove the Panel from the back plastic with the stand...
                  I see there are screws under the stand mount that looks like is mounted to the panel, but it's inaccessible.
                  • jjpjimmy
                    • Jan 2011
                    #89
                    I've got the monitor open now. I found two capacitors that are bulging on the top of the left most board (the inverter?).
                    I'm going to replace all 4 on this board to be safe, but I'm wondering if I should replace every capacitor. There aren't any bulging capacitors on the power supply, but there might be a baddy in there as well....
                    To be sure I'm going to purchase (4) 100uF 35v 11.5mm(H)x 8mm(Dia), but I'm wondering what company (Nichicon vs. Panasonic) should I purchase expecting high temperatures.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #90
                      Yes, that is the inverter board.
                      Definitely replace all the caps on the inverter board. The power board seems to have United Chemi-con caps (the brown cap with crown symbol). They generally make good caps, but their KZG series are problematic.
                      Panasonic FM caps are a favourite here, but Nichicon makes low ESR caps as well. See
                      https://www.badcaps.net/forum/showthread.php?t=2280
                      • ben3843100
                        • Jan 2011
                        • 25
                        #91
                        Hello all,
                        My name is Ben and I'm new to this site. Just thought I would take the time to say "hi" and relay that I have three of these L2410NM LCD monitors, one of which I am in the midst of repairing.
                        As an fyi, I ordered my L2410NM replacement caps through the http://www.lcdalternatives.com/ website. I could have ordered them myself but I was lazy. When I ordered my replacement cap kit for the L2410NM I received the wrong set of caps. I didn't catch it initially when looking through the pics on this thread (thanks to all who have provided information), but there are apparently at least two different power supply boards used in the L2410NM, and LCD Alternatives supplied the caps for the other board (the board I don't have). I'm working with him and have supplied him with pics of both board versions, but in case someone here orders caps from that site, you may want to send a pic of your board along with your order. I'm not endorsing the site, but it seemed relevant to the discussion.
                        Ben
                        Version 1: (Parts I received)
                        1 10v 2200uF
                        1 25v 1500uF
                        2 25v 1000uF
                        2 35v 680uF
                        1 25v 100uF
                        Version 2: (my PS board)
                        1x 25v 330uF
                        1x 25v 410uF
                        1x 35v 1000uF
                        2x 35v 470uF
                        2x 50v 22uF
                        3x 25v 100uf
                        Version 2: (my Inverter board)
                        4x 35v 100uF
                        • jetadm123
                          • 2169
                          #92
                          Originally posted by ben3843100
                          Hello all,
                          Ben
                          1 10v 2200uF
                          1 25v 1500uF
                          2 25v 1000uF
                          2 35v 680uF
                          1 25v 100uF
                          1x 25v 330uF
                          1x 25v 410uF
                          1x 35v 1000uF
                          2x 35v 470uF
                          2x 50v 22uF
                          3x 25v 100uf
                          4x 35v 100uF
                          Unfortunately, you learned the hard way that manufacturers use multiple power supply manufacturers for their monitors. Even a different revision of the same board may have different caps. Before ordering any kit, open up the monitor first and compare your board to the one in their photo and match up one for one the caps supplied in the kit to the ones on your board. This is also why we always ask for photos when rendering help to a member.
                          • Boregy
                            • Dec 2010
                            • 21
                            #93
                            I need to buy a soldering iron (never soldered before).
                            Can someone recommend which I should choose between these 2:
                            30W
                            http://www.dealextreme.com/p/30w-ele...-110v-ac-22264
                            40W
                            http://www.dealextreme.com/p/keji-40...cm-cable-25659
                            or any other recommendation.
                            Thank you.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #94
                              If you are only going to solder once or twice, then I would look on ebay for the cheapest 40W soldering iron. I use this method myself and pay about $2.99 USD. I have used this iron to repair about 14+ monitors.
                              The irons on ebay are probably come from the same factory as DealExtreme.
                              This website has an excellent guide on soldering at FAQ section
                              https://www.badcaps.net/forum/showthread.php?t=485
                              The video solder video is by Curious Inventor at
                              http://www.youtube.com/watch?v=I_NU2ruzyc4
                              • ben3843100
                                • Jan 2011
                                • 25
                                #95
                                -links removed-
                                Thank you.
                                If you have a Radio Shack near you (or online), they have a nice 45 watt de-soldering iron for only $10.99. I'm no pro, but I picked one up and it was very easy to remove the caps on my LCD power supply board with the special tip and suction bulb. I haven't tried the following, but you may be able to swap the tip for a standard soldering tip available from Radio Shack and use it as a regular soldering iron as well.
                                http://www.radioshack.com/product/in...ductId=2062731
                                -Ben
                                • jjpjimmy
                                  • Jan 2011
                                  #96
                                  Hi I've replaced the 4 capacitors on the Inverter and there has been a little progress in that the monitor shows at least some lines of the color (BIOS blue), from nothing at all. I'm hearing a whine/high pitched noise from the Power Supply; and I'm going to purchase replacement capacitors for the power supply (I've got the version 2 listed above by ben3843100) and I'd like to run final checks for these...
                                  35v1000uF
                                  (x3) 25v100uF
                                  25v330uF
                                  25v470uF
                                  (x2) 35v470uF
                                  (x2) 50v22uF
                                  420v120uF
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #97
                                    Assuming the height and diameter work for the replace FC with FR.
                                    100uF 25V use Panasonic FR P14413-ND
                                    22uF 50V use Panasonic FR P14452-ND
                                    1000uF 35V, use Panasonic FM P12405-ND
                                    • kosh
                                      • Jan 2011
                                      #98
                                      I have the same monitor and it has just failed also. Yesterday it started to make a high pitched whine so I turned it off. By high pitched whine I mean it had such a high pitch that nobody else around could even hear it but it went off when I turned the power off so it clearly was coming from the monitor and that is where I heard it from. When I tried to turn it on today it would not turn on at all. The power light flickered very briefly on and that is it.
                                      Is it likely that the caps have gone bad on the board also? I opened it up and can see no sign of burning anywhere but one cap is very slightly bulged at the top.
                                      Is it worth it to try and repair it or just replace it? What are the odds that if it is the caps that something else is broken now as a result even though I can see no signs of damage anywhere.
                                      Considering that it lasted out of the warranty I can't get it repaired that way. It also looks like most repair places charge enough that I would be better off getting another monitor then using them.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        First, I would judge there is a 75% chance that replacing the caps will repair the monitor. A 'slight bulge' indicates the cap has failed. Caps can fail without any visible signs - some manufacturers are skilled on making that happen.
                                        As far as repair vs replace, there are several factors to consider.
                                        1. How are your soldering skills? If you never soldered, this is not the easiest way to learn. Still, it's not a great stretch - it's not like we are talking about replacing a 400 pin IC. (Since you did not report problems getting the monitor open, I assume your mechanical skills are up to the task.)
                                        2. How badly do you need the monitor? You could get a replacement today; you won't be able to get the caps until Wednesday.
                                        3. What is your financial situation? An equivalent monitor will run $250 - $300 while a full set of caps will run under $15 from Digikey (USPS First Class shipping).
                                        4. How badly do you want a new monitor? Balance the points of bragging 'I fixed it myself' vs 'I bought a new 25" monitor Saturday'.
                                        In the event you decide to replace the monitor, let me know. I'd gladly pay shipping (assuming you are in the USA). A guy can't have too many 24" monitors on hand.
                                        PlainBill
                                        • kosh
                                          • Jan 2011
                                          #100
                                          Oh I got the monitor open just fine and I can solder things.
                                          It is one of a set of 4 monitors so I can use the other 3 for now I would just prefer not to get a new one if I don't have to.
                                          It is hard to find a good PVA panel and I really like them for programming work.
                                          When I did some experiements with TN panels I found that did not work very well with strange color shifting from top to bottom and side to side that I found distrating.
                                          IPS I have not liked as much for text work as PVA panels.
                                          [/QUOTE]
                                            Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:50 AM
                                            Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
